hi,
i have 2 windows server 2016 servers connected together with a LAN network:
server 1 = DC server + DNS server
server 2 = hyper v host + DHCP and DNS server
now i got DHCP to work with hyper v to give my test windows 7 VM an IP address, and i can get the dns records on my windows 7 test vm from server 1
now my question is, can i share the internal network card from server 2 to server 1?
thank you for answering!
https://linustechtips.com/topic/1229259-i-need-help-with-hyper-v/
Are the servers on different subnets? If so you'll need a static link setting up between them so they can talk directly to each other.
Main Rig:-
Server:-
4 minutes ago, Electronics Wizardy said:
why not mke server 1 a hyper-v server too? Running your dc on vm is fine.
What do you mean share a network card? If all the servers are in the same l2 everything should be able to talk to each other.
well, that is an option.
here is the network configuration
server 1: nic1 = 192.168.1.2
server 2: nic1 = 192.168.1.1
server 2: internal hyper v network card = 192.168.15.1
windows 7 test vm: hyper v network card = 192.168.15.2
now i want to give server 1 an ip address on 192.168.15.X
The 2 servers can talk to each other, but the windows 7 test vm cant talk to server 1
then you seem to hve some sort of nat going on here. Is the network adapter in the hyper-v server set to bridged?
the hyper v server has 2 network adapters:
NIC 1 with an ip of 192.168.1.1
NIC 2 (hyper v internal network) with an ip of 192.168.15.1
Can we clarify, are both servers VM or is one physical and the second a VM?
Main Rig:-
Server:-
that internet network is your problem, you need to have a bridged connection in the vms, not a nat or internal network.
both of the servers are VMs
Then it looks like you have one VM set to direct connect and the other VM set to use a bridge. I'll leave this one to @Electronics Wizardy since he has more experience with networking than I do.
Main Rig:-
Server:-
here is the screen shot from my hyper v host (its the virtual network that is connected to my windows 7 test vm
you want to select external network. Then select the network card it sould be connected to.
2 minutes ago, Ofir aviel said:
well, i am connected using RDP so i didn't see the actual bsod screen
Did you setup a virtual switch in the hyper-v host setttings?
Are you sure it crashed, it may have lost connectivity to the host
This seems to be a virtual machine, can you connect to the hypervisor on the host
Also if its all running in a virtual machine, why not just run anouther vm on the host.
yes i did.
yes, when i reconnected, it showed me the windows shutdown event tracker
3 minutes ago, Electronics Wizardy said:
why not just make anouther vm on the host with windows 7?
What exact bsod do you get?
well, because i want to see if there is another method to do this other then another VM.
well, i recorded the VNC screen in slow motion and saw that the bsod was:
Quote
system thread exception
Try a different network adapter for the vm, that might be the issue here. Set it to something like e1000, or add anoutehr nic to the vm.
That should work as it is, so there seems to be a issue with your nested virt setup.
well, i tried to create a new virtual network adapter, and the server crushed again.....
