1. Im curently using a Sun Pro ATX-550W PSU. It has on the sticker the following numbers etc: 17A on 12v+ and 0.8A on 12v - . What do these numbers mean and is this power supply ok to use?
2. The power supply doesnt have an 8 pin motherboard plug it only has a 4 pin one, is this ok? will it or could it damage anything etc?
https://linustechtips.com/topic/122890-sun-pro-psu/
I wouldn't trust them or it. Not sure what those numbers mean, but don't trust the brand PSU's are a big thing of a computer never cheap out on them.  As for your second question, wouldn't it just not give the right amount of power then? Correct me if I am wrong <<<<
Current Build: Case: Define R4 White/Window CPU: i5 3470 @4.0Ghz GPU: GTX 680 DCUII +500Mhz(Mem) Cooler: Hyper 212 EVO Monitor: Acer Monitor 1920x1080 MOBO: Asrock Z77 Extreme 4 Storage: 2TB HDD, 120GB 840 EVO (OS)
Future Build: 4670K, GTX 780 MSI TwinFrozr OC, Z87X-D3H, 8GB @1866Mhz, 120GB SSD, 1TB HDD, 750D, RM 650W, Custom Loop. White/Blue/Black Colour Scheme. I literally cannot wait *_*
https://linustechtips.com/topic/122890-sun-pro-psu/#findComment-1634948
never heard of sun pro form the pictures they dont look very reliable id switch soon also sorry i dont know what the numbers mean
Specs
https://linustechtips.com/topic/122890-sun-pro-psu/#findComment-1634965
would it power a amd 7770msi 1gb not overclocked and a fx 4130 amd cpu not overclocked and 2 3.5inch hard drives and 1 120mm rear exhaust cooling fan and two 140mm front intake cooling fans and 8gb of gskill 1600mhz ram and the motherboard is a AsRock 980DE3/U3S3 ?
https://linustechtips.com/topic/122890-sun-pro-psu/#findComment-1634966
Mines worse.. Power-Up, then when i google the model number it came up as "Axio"
(NOW)War Horse:
CPU: AMD FX-6300 | Motherboard: MSI 970A-G43 | RAM: Corsair Vengeance Dual Channel 8GB 1600Mhz | GPU: MSI R7790 | Case: Dazumba D-Vito 903 | HDD 1 & 2: Seagate 1TB and Seagate 500GB | PSU: Corsair CX600
(WAS)Old Coop:
CPU: Intel C2D E7500 | Motherboard: Gigabyte G31M-ES2L | RAM: V-Gen 4GB Dual Channel | GPU: Galaxy GT210 | Case: Power-Up ??? | HDD: Seagate 500GB | PSU: Power-up 500W
MyAnimeList Profile | Heaven Society | HEIL THE MIGHTY AND POWERFUL LINUS | My Blog 'Unfinished Pieces' | Code of Conduct
https://linustechtips.com/topic/122890-sun-pro-psu/#findComment-1634973
It may, 550W seems plentiful, but I have never heard of the brand and wouldn't ever trust them in any of my builds.
https://linustechtips.com/topic/122890-sun-pro-psu/#findComment-1634975
dont use this psu , otherwise you may lose everything you have. This is due to the fact it is not 80+ rated and the brand is not a trusted well known one. Save money up for a bit and get a better psu otherwise it will cost you alot more
CPU 5900x| GPU 3080ti FE| MOBO MSI MPG CARBON MAX| RAM 32GB VENGENCE PRO 3200Mhz| STORAGE Samsung 980 Pro 1TB,2X WDSN750,4TB Seagate Barracuda| COOLING 1x Corsair 360mm XR7 54mm Radiator,1x EK-CoolStream PE 360mm Radiator| GPU Block: Corsair Hydro X Series, XG7 RGB| CPU Block: Corsair Hydro X Series, XC5 RGB| Fittings: EK-Torque STC & Corsair Hydro X Series XF| Pump/Res: EK-Quantum Kinetic TBE 300 D5| Tubing: Corsair Hydro X Series XT Softline| Liquid: Corsair Hydro X Series XL5 Clear| Fans: 10x Corsair SP120 RGB
https://linustechtips.com/topic/122890-sun-pro-psu/#findComment-1635109
Theoretically the PSU should be able to power that setup, though it is a very very basic generic unit and I don't recommend using it at all, because eat might blow up and destroy all of your other parts. Just buy something from a reputable brand with at least 80+ Bronze certificate. If you are on a budget, something like the Corsair CX 500 or CX 600 is a good option. Also the Cooler Master GM Series PSUs.
CPU: AMD Ryzen 9 - 3900x @ 4.4GHz with a Custom Loop | MBO: ASUS Crosshair VI Extreme | RAM: 4x4GB Apacer 2666MHz overclocked to 3933MHz with OCZ Reaper HPC Heatsinks | GPU: PowerColor Red Devil 6900XT | SSDs: Intel 660P 512GB SSD and Intel 660P 1TB SSD | HDD: 2x WD Black 6TB and Seagate Backup Plus 8TB External Drive | PSU: Corsair RM1000i | Case: Cooler Master C700P Black Edition | Build Log: here
https://linustechtips.com/topic/122890-sun-pro-psu/#findComment-1635267
ok thanks, is the Corsair CX500 good for quality etc? is it worth buying? to just run a amd 7770 or 7850 in with an i5 4670k? and or difference from my fx 4130?
https://linustechtips.com/topic/122890-sun-pro-psu/#findComment-1635438
Yes, it is a good quality unit and it will serve you well. :)
https://linustechtips.com/topic/122890-sun-pro-psu/#findComment-1636182
will the CX500 run a amd 7770 or 7850 with an i5 4670k? and how much less power will the i5 use from my fx 4130?
That PSu will have enough juice to power each of those setups. The i5 and the 4130 use pretty much the same amount of power.
https://linustechtips.com/topic/122890-sun-pro-psu/#findComment-1646382
ok any references / proof of your words? i always thought amd cpu and gpu use more power than intel and nvidia hardware?
Usually yes, but that is not the case, because the 4130 is not that power hungry like the 6300 or the 8350 or even the stupid 9590.
https://linustechtips.com/topic/122890-sun-pro-psu/#findComment-1646413
https://linustechtips.com/topic/122890-sun-pro-psu/#findComment-1646619
