I recently purchased NZXT X62 but tube is not presentable is there anyway I can fix the tube position to be more presentable? Are tubes sensitive that will cause leakage or damage while bending or moving the tubes?>
2020 Build: AMD R5 3600 | AMD AORUS RX 5700 XT | AORUS B450M | 16GB Thermaltake Z-One DDR4-3200 | Samsung 970 Evo Plus | Corsair RM650 | NZXT X63 | Corsair Crystal 280x | 2x Purewings 140mm PWM
https://linustechtips.com/topic/1228759-aio-tubing/
Excessively sharp bends and/or unnatural shapes can cause leaks and kinks/increased flow resistance, especially over time, at the joints, but they are made to be flexible within reason. Adjusting the orientation of the radiator, and/or different mounting locations can help. You won't be able to replace the tubes with something longer, if you're considering doing this. If at all possible (I'm sure someone somewhere has done so to varying degrees of success), it will be cost prohibitive.
~Remember to quote posts to continue support on your thread~
-Don't be this kind of person-
CPU:  AMD Ryzen 7 5800x | RAM: 2x16GB Crucial Ripjaws Z | Cooling: XSPC/EK/Bitspower loop | MOBO: Gigabyte x570 Aorus Master | PSU: Seasonic Prime 750 Titanium
SSD: 250GB Samsung 980 PRO (OS) | 1TB Crucial MX500| 2TB Crucial P2 | Case: Phanteks Evolv X | GPU: EVGA GTX 1080 Ti FTW3 (with EK Block) | HDD: 1x Seagate Barracuda 2TB
https://linustechtips.com/topic/1228759-aio-tubing/#findComment-13875567
how about a picture of your current config
what case you have
https://linustechtips.com/topic/1228759-aio-tubing/#findComment-13875590
Im not sure, I think I can do better than this. Any ideas or suggestions? case is corsair crystal 280x
https://linustechtips.com/topic/1228759-aio-tubing/#findComment-13875827
I think the rad position is on top since it wouldn’t fit on front. I can’t picture out on How can I rotate the pump yet.
https://linustechtips.com/topic/1228759-aio-tubing/#findComment-13875831
Can you flip the rad 180 so that the tubes loop under the block and run up the back? IMO AIOs always look tidier with that sort of J shaped run.
[ P R O J E C T _ M E L L I F E R A ]
[ 5900X @4.7GHz PBO2 | X570S Aorus Pro | 32GB GSkill Trident Z 3600MHz CL16 | EK-Quantum Reflection ]
[ ASUS RTX4080 TUF OC @3000MHz | O11D-XL | HardwareLabs GTS and GTX 360mm | XSPC D5 SATA ]
[ TechN / Phanteks G40 Blocks | Corsair AX750 | ROG Swift PG279Q | Q-Acoustics 2010i | Sabaj A4 ]
P R O J E C T | S A N D W A S P
6900K | RTX2080 | 32GB DDR4-3000 | Custom Loop
https://linustechtips.com/topic/1228759-aio-tubing/#findComment-13875987
i was thinking the same thing,
still might be a lot of slack do to the case.
you could try coiling the hoses around the block like:
some zip ties acting as a cable comb in whatever config may help too.
https://linustechtips.com/topic/1228759-aio-tubing/#findComment-13876041
