3200G reserves up to 2gb of RAM for integrated video. It's important for APUs to have sufficient memory for this reason.
i5-14600KF // 120x38MM Cooler Master AIO // B760i // 64GB DDR5 6000 // PNY RTX 5070 // Cooler Master NCORE 100 Max // Cooler Master V SFX-850 Gold // UWQHD AOC Display
https://linustechtips.com/topic/1228621-computer-ram-problem/#findComment-13874487
Well first of all. 2 gigs is usually used as a frame buffer for the apu.
Second of all.  Not sure what software is that. But what does something like task manager say? If the 5 gigs is available memory. Then that's fine for the most part. As I said. Usually 2 gigs as default for the apu. And windows does use some for system responsiveness etc.
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1228621-computer-ram-problem/#findComment-13874490
