Hi ,
Sometime around 5 months ago a small black zone appeared on the bottom-middle of the screen. I though that it was something stuck between the bezzel and the screen so I tried to take the plastic out and inspect it. There was nothing between there and I also managed to make a small crack on the screen (barely visible), but the black zone has expanded significantly. Is there a way to fix this or should I replace it right away?(see picture for the black zone)
Tech enthusiast from the land of dept ( Greece ) and casual overclocker. If it has a processor i will overclock it, monitor yes, my car's ecu yes, my brain... yes.
MAIN PC R5 5500 / 32GB RAM / 6900XT
SERVER : i7 2600 / 12GB RAM / 8TB
https://linustechtips.com/topic/1228126-any-advice-for-a-fix-for-this/
20 minutes ago, JewPacaBraZ said:
Hi ,
i had same problem replace the display it will only get worse
if it was useful give it a like :) btw if your into linux pay a visit here
Thank you kind sir , will do soon enough , much love
it's a hardware issue, your display substrate is damanged and it leaks its liquid crystal content
there's nothing you can do about it - may be a specialised display repair shop can do something about it but I think it will cost you close to buying a new monitor altogether
Thank you kind sir , i will see if i can get a repair
