Unless it is a very bad psu, it doesn’t sound the power supply is the issue. It sounds like there is an issue with the graphics card. My guess is bad/dead vram. Did you have this problem prior to putting in the 2070 super?
I am far from an expert in this so please correct me if I’m wrong.
Quote or tag me so I can see your response
PSU Tier List
Motherboard Tier List
Graphics Card Cooling Tier List
CPU Cooler Tier List
SSD Tier List
PARROT GANG
Mentioned in 7/10/20 WAN Show
Mentioned in 7/15/20 Techlinked
Mentioned in 7/17/20 Techlinked
Mentioned in 7/31/20 WAN Show
Mentioned in 7/31/20 Techlinked
Mentioned in 8/3/20 Techlinked
Mentioned twice in 8/5/20 Techlinked
Mentioned twice in 8/7/20 Techlinked
Mentioned in 8/12/20 Techlinked
Mentioned in 8/19/20 Techlinked
https://linustechtips.com/topic/1227940-psu-help/#findComment-13868797
I have a 500 watt 80 plus certified it isn’t 80 plus bronze. And I’m going to try with my rx 570 to see if I still have a problem
https://linustechtips.com/topic/1227940-psu-help/#findComment-13868802
Do you know what specific model?
PSU Tier List
SSD Tier List
PARROT GANG
https://linustechtips.com/topic/1227940-psu-help/#findComment-13868805
6 minutes ago, Ghostly224 said:
Yea
I couldn't find it on the psu tier list, but my guess is that is a lower end psu. However, it is good enough that it shouldnt be causing your issue. If you dont have the issue when you switch to a different graphics card, then you know for sure it is the 2070 super. In that case, contact the manufacturer about an rma to get a replacement.
Also, I would recommend upgrading to a better quality psu whenever possible.
PSU Tier List
SSD Tier List
PARROT GANG
https://linustechtips.com/topic/1227940-psu-help/#findComment-13868838
I think I’m just going to upgrade both then
https://linustechtips.com/topic/1227940-psu-help/#findComment-13868851
Wait so 500 watt is enough for rtx 2070 super and Ryzen 5 3600?
https://linustechtips.com/topic/1227940-psu-help/#findComment-13868866
Yes, the wattage is enough it just isn’t a high quality power supply. Take a look at the psu tier list in my signature, any of the ones in theirs b+ or above would be great for you.
PSU Tier List
SSD Tier List
PARROT GANG
https://linustechtips.com/topic/1227940-psu-help/#findComment-13868890
