Hi I’m gonna build my first machine for gaming and coding I can’t choose between the and Ryzen 5 or 7 3700x is gonna play fortnite, Destiny 2, forza horizon 4, and others with be games like beatsaber I’m not a forums guy so please don’t complain and just tell me what cpu I should get (btw I’m on a budget)
https://linustechtips.com/topic/1227923-what-cpu-should-i-use/
A 3600 should be plenty for the workloads you mentioned. If the 3700X would be a stretch for your budget or you'd have to sacrifice on another component to fit it in, I'd just get the 3600.
If you need help picking out other parts of your system, you could just create a thread on the New Builds and Planning subforum and you'll likely get some useful insight, here:
https://linustechtips.com/main/forum/18-new-builds-and-planning/
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
https://linustechtips.com/topic/1227923-what-cpu-should-i-use/#findComment-13868620
Saying you're on a budget is pointless if you're not going to tell us what the budget is.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/1227923-what-cpu-should-i-use/#findComment-13868621
