9 minutes ago, gloop said:
Change it the PSU for a CX.
Thanks
31 minutes ago, PeachGr said:
I use 2060 super. For Apex I guess 2060 is good, and you can adjust the settings anyways, I don't know about fps thou, if you are on 144htz it's a different story (nobody will notice on stream, but you will on gameplay)
Thanks
https://linustechtips.com/topic/1227604-help/#findComment-13866406
