I have the build above, and my CPU seems to idle at around 50-60C. The only thing I've changed in bios of XMP for RAM. Any ideas? I tried re-seating the cooler and using new thermal paste. I checked this temp using hwinfo as well as in the bios and in ryzen master. Any ideas?
https://linustechtips.com/topic/1227102-high-cpu-temps/
Are you sure that idle really is idle, as in you don't have some random background task loading the CPU?
Are you running the latest BIOS?
What temperatures do you get at full load, and what Vcore?
Ambient temps?
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
https://linustechtips.com/topic/1227102-high-cpu-temps/#findComment-13862116
1 hour ago, Hackentosher said:
Ehhh, 50 is a little high for idle, 60 certainly is. Are you sure the system is at idle? Like <10% CPU load? Maybe the cooler isn't on tight enough or the fans aren't spinning fast enough?
Ambient temps?
https://gyazo.com/98ed43f136e003a1c082c9a8a0fcebb0
https://linustechtips.com/topic/1227102-high-cpu-temps/#findComment-13862263
9 minutes ago, Viper_the1st said:
Make sure you're running the latest chipset drivers and that you're using the Balanced power plan in Windows.
Run a load on the CPU, and note down the Vcore while at full load (the ones shown in the screenshot you sent are VID, not Vcore, not the same thing).
https://linustechtips.com/topic/1227102-high-cpu-temps/#findComment-13862284
which 1's vcore
https://linustechtips.com/topic/1227102-high-cpu-temps/#findComment-13862292
To be honest I would say your temps are what I would expect with a 240 rad on this CPU.  I would probably upgrade to a 360.  I have a 9900k, which does run slightly hotter than yours.  But even with a 280 rad I hit the 90s with it.  I had to upgrade to a 360 to get the highs below 80.
https://linustechtips.com/topic/1227102-high-cpu-temps/#findComment-13862501
no worries.I have same CPU same temps...enjoy in your build.
Please do not take offence for my apparent confusion or rudeness,it's not intent me to be like that,it's just my BPD,be nice to me,and I'll return twice better,be rude and usually I get easly pissed of...I'll try to help anyone here,as long as it's something I dealt with,and even if you think I'm rude or not polite,forgive me,  it's not me it's my BPD.
Thanks for understanding.
https://linustechtips.com/topic/1227102-high-cpu-temps/#findComment-13863151
