Hi everyone,
I have a Corsair Carbide 678C computer case and a Asus ROG Strix B550 F-gaming motherboard and was wanting to know what kind of power supply am i going to need to run a amd ryzen 7 3700x or a ryzen 5 3600 and a asus rog strix geforce rtx 2070. I want a brand that is going to be reliable and have plenty of wattage. I was thinking 1000 watt but is that overkill? I'm also considering 850w as well. Thanks for help.
https://linustechtips.com/topic/1226736-choosing-a-power-supply/
Yes, 1000 watts is overkill. You should be fine with even with 600w, 750w if you plan to overclock or want to futureproof. Use the following to choose your PSU:
Make sure to quote me or use @PorkishPig to notify me that you replied!
Desktop
CPU - Ryzen 9 3900X | Cooler - Noctua NH-D15 | Motherboard - ASUS TUF X570-PLUS RAM - Corsair Vengeance LPX DDR4-3200 32GB Case - Meshify C
GPU - RTX 3080 FE PSU - Straight Power 11 850W Platinum Storage - 980 PRO 1TB, 960 EVO 500GB, S31 1TB, MX500 500GB | OS - Windows 11 Pro
Homelab
CPU - Core i5-11400 | Cooler - Noctua NH-U12S | Motherboard - ASRock Z590M-ITX RAM - G.Skill Ripjaws V DDR4-3600 32GB (2x16)  | Case - Node 304
PSU - EVGA B3 650W | Storage - 860 EVO 256GB, Sabrent Rocket 4.0 1TB, WD Red 4TB (x6 in RAIDZ1 w/ LSI 9207-8i) | OS - TrueNAS Scale (Debian)
What's your budget for the PSU?
A 1000W unit could probably power three 3700X+2070S systems at once - it'd be totally overkill and granted quite a pointless purchase.
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
