Xonar Essence STX buzzing sound with microphone
CanadianMike
Hello everyone!
I was testing JNK microphones with the Xonar Essence STX I have installed. The microphones aren't as sensitive as I'd like them to be so i cranked up the gain, but by increasing gain it introduced some buzzing noises. Some additional info is the microphones have a 600 ohm rating and I used a XLR to 1/4 cable. I have reinstalled the sound card drivers and turned down the gain, but then it barely picks up any sound.
I was wondering if anybody could help with my issue, thanks!
Don't those need a XLR pre-amp to boost signal for soundcard ?
CPU : Core i7 6950X @ 4.26 GHz + Hydronaut + TRVX + 2x Delta 38mm PWM
MB : Gigabyte X99 SOC (BIOS F23c)
RAM : 4x Patriot Viper Steel 4000MHz CL16 @ 3042MHz CL12.12.12.24 CR2T @1.48V.
GPU : Titan Xp Collector's Edition (Empire)
M.2/HDD : Samsung SM961 256GB (NVMe/OS) + + 3x HGST Ultrastar 7K6000 6TB
DAC : Motu M4 + Audio Technica ATH-A900Z
PSU: Seasonic X-760 || CASE : Fractal Meshify 2 XL || OS : Win 10 Pro x64
Thanks for the reply.
I'm not sure, i'm really new to audio related things, I thought it would be plug and use. Could you please elaborate what you mean?
