Radiator fans
Go to solution Solved by Grabhanem,
My 2C as someone who runs NF-A12x25s on a radiator: they're worth it. I'm on a pretty small radiator setup (240 for both CPU and GPU) and with proper fancurves my fans are barely audible under load.
I don't think push/pull is worth the extra $90 tho, three fans even through a radiator will give plenty of case airflow especially if you have proper exhaust fans.
Hi,
I have NZXT kraken X72 with 3 default fans on it. They get pretty noisy even at Silent fan profiles. Would getting 6x NOCTUA NF-A12x25-PWM fix the issue? Will this be worthy investment that will improve a. performance and b. acoustics.
(btw I have NZXT 710i case and CPU is 3900X @4.45GHz)
Thanks a lot :)
https://linustechtips.com/topic/1225820-radiator-fans/
Basically yes. The NOCTUA fans are known to provide better air flow with less noise. I'm sure 6 of them running full speed would still be a bit noisy, but you probably won't need full speed with 6 in push pull.
BabyBlu.2 (Primary):
  • CPU: AMD Ryzen 5 9600X
  • Motherboard: Asus ROG STRIX B650E-F
  • RAM: G.Skill Flare X5 64GB (2x32GB) DDR5-6000 CL30 @ 6400MHz 30-40-40-96
  • GPU: MSI RTX 2080 Sea Hawk EK X, 2100MHz core, 8000MHz mem
  • Case: Phanteks Evolv X
  • Storage: XPG SX8200 Pro 2TB, 3x ADATASU800 1TB (RAID 0), Samsung 970 EVO Plus 500GB
  • PSU: Corsair HX1000i
  • Display: MSI MPG341CQR 34" 3440x1440 144Hz Freesync, Dell S2417DG 24" 2560x1440 165Hz Gsync
  • Cooling: Custom water loop (CPU & GPU), Radiators: 1x140mm(Back), 1x280mm(Top), 1x420mm(Front)
  • Keyboard: Corsair Strafe RGB (Cherry MX Brown)
  • Mouse: MasterMouse MM710
  • Headset: Corsair Void Pro RGB
  • OS: Windows 11 Pro
Roxanne (Wife Build):
  • CPU: AMD Ryzen 5 7600
  • Motherboard: Gigabyte B650I AORUS ULTRA
  • RAM: G.Skill Flare X5 32GB (2x16GB) DDR5-6000 @ 6000MHz 30-38-38-96
  • GPU: EVGA GTX 1080 FTW2 w/ LM
  • Case: Cooler Master MasterBox NR200
  • Storage: Samsung 850 EVO 250GB, Samsung 860 EVO 1TB, Silicon Power A80 2TB NVME
  • PSU: Corsair SF850L
  • Display: Dell Alienware AW3420DW GSync
  • Cooling: Arctic Liquid Freezer II 280mm
  • Keyboard: GMMK TKL(Kailh Box White)
  • Mouse: Glorious Model O-
  • Headset: SteelSeries Arctis 7
BigBox (HTPC):
  • CPU: Ryzen 5800X3D
  • Motherboard: Gigabyte B550i Aorus Pro AX
  • RAM: Corsair Vengeance LPX 2x8GB DDR4-3600 @ 3600MHz 14-14-14-28
  • GPU: MSI RTX 3080 Ventus 3X Plus OC, de-shrouded, LM TIM, replaced mem therm pads
  • Case: Fractal Design Node 202
  • Storage: SP A80 1TB, WD Black SN770 2TB
  • PSU: Corsair SF600 Gold w/ NF-A9x14
  • Display: Samsung QN90A 65" (QLED, 4K, 120Hz, HDR, VRR)
  • Cooling: Thermalright AXP-100 Copper w/ NF-A12x15
  • Keyboard/Mouse: Rii i4
  • Controllers: 4X Xbox One & 2X N64 (with USB)
  • Sound: Denon AVR S760H with 5.1.2 Atmos setup.
Harmonic (NAS/Game/Plex/Other Server):
  • CPU: Intel Core i7 6700
  • Motherboard: ASRock FATAL1TY H270M
  • RAM: 64GB DDR4-2133
  • GPU: Intel HD Graphics 530
  • Case: Fractal Design Define 7
  • HDD: 3X Seagate Exos X16 14TB in RAID 5
  • SSD: Inland Premium 512GB NVME, Sabrent 1TB NVME
  • Optical: BDXL WH14NS40 flashed to WH16NS60
  • PSU: Corsair CX450
  • Display: None
  • Cooling: Noctua NH-U14S
  • Keyboard/Mouse: None
  • 2.5Gb NIC
  • OS: Windows 10 Pro
NAS:
  • Synology DS216J
  • 2x8TB WD Red NAS HDDs in RAID 1. 8TB usable space
https://linustechtips.com/topic/1225820-radiator-fans/#findComment-13851771
3 minutes ago, Korben said:
I would start with 3. 6 is still double the noise... and if you think of running 6 of  them at half speed.. they would probably still sound like 3 on a normal profile :) Just waisted money imo.
I want 6 because only case intake goes through the radiator first so I want to have more air to come throught, thats why I think 6 fans would be better (but its just my assumption).
https://linustechtips.com/topic/1225820-radiator-fans/#findComment-13851791
Push Pull is only marginally better than Push or Pull only when running high RPM, but at low RPM Push Pull will out perform Push or Pull only. So if you want silence and low RPM then Push Pull is the way to go to still get good cooling.
BigBox (HTPC):
  • Display: None
  • 2.5Gb NIC
NAS:
  • Synology DS216J
https://linustechtips.com/topic/1225820-radiator-fans/#findComment-13851811
Dont believe the hype. Just look at the dB numbers from U12A review. And the performance difference is also tiny. Get a 5 pack of the p12 pwm pst:s from arctic for the price of one Noctua fan.
missing-image.svg
https://www.tomshardware.com/reviews/noctua-nh-u12a-cooler,6372-2.html
https://linustechtips.com/topic/1225820-radiator-fans/#findComment-13851841
missing-image.svg
I dont think the usecase will be the same for me, they tested it on a aircooler with a really open space. Where I would be using them in a restricted space when they need to push more air. Also for me performance>noise, but what I have problem with that even on silent NZXTdefault fans like to ramp up to 100% for a few seconds and then go back
https://linustechtips.com/topic/1225820-radiator-fans/#findComment-13851872
Well what you have there is a bad fan curve. Most likely you can adjust it to your liking without buying new fans for 180$.
https://linustechtips.com/topic/1225820-radiator-fans/#findComment-13851880
@Jeppes, @Belgar
Yeah that chart doesn't look relevant (it's about the stock performance of different air coolers not fans) or even very good to begin with (what does 50% speed mean?)
It sounds like you should try setting a custom fan curve before buying new fans.
BigBox (HTPC):
  • Display: None
  • 2.5Gb NIC
NAS:
  • Synology DS216J
https://linustechtips.com/topic/1225820-radiator-fans/#findComment-13851884
2 minutes ago, HairlessMonkeyBoy said:
@Jeppes, @Belgar
It is but with OC it runs really hot really fast and I dont feel comfortable running CPU at 85C during load under water, plus it heats everything else since rad is at the intake
https://linustechtips.com/topic/1225820-radiator-fans/#findComment-13851892
As someone running 10 Arctic P12's in his loop at full blast (push pull on 3 radiators) - I concur with going with those to save a buck, the sone they produce is mild and pleasing.
Noctua is quite an investment.  Arctic P12 value packs can be found between 27-30 regularly when on sale
Workstation Laptop: Dell Precision 7540, Xeon E-2276M, 32gb DDR4, Quadro T2000 GPU, 4k display
Wifes Rig: ASRock B550m Riptide, Ryzen 5 5600X, Sapphire Nitro+ RX 6700 XT, 16gb (2x8) 3600mhz V-Color Skywalker RAM, ARESGAME AGS 850w PSU, 1tb WD Black SN750, 500gb Crucial m.2, DIYPC MA01-G case
My Rig: ASRock B450m Pro4, Ryzen 5 3600, ARESGAME River 5 CPU cooler, EVGA RTX 2060 KO, 16gb (2x8) 3600mhz TeamGroup T-Force RAM, ARESGAME AGV750w PSU, 1tb WD Black SN750 NVMe Win 10 boot drive, 3tb Hitachi 7200 RPM HDD, Fractal Design Focus G Mini custom painted.
NVIDIA GeForce RTX 2060 video card benchmark result - AMD Ryzen 5 3600,ASRock B450M Pro4 (3dmark.com)
Daughter 1 Rig: ASrock B450 Pro4, Ryzen 7 1700 @ 4.2ghz all core 1.4vCore, AMD R9 Fury X w/ Swiftech KOMODO waterblock, Custom Loop 2x240mm + 1x120mm radiators in push/pull 16gb (2x8) Patriot Viper CL14 2666mhz RAM, Corsair HX850 PSU, 250gb Samsun 960 EVO NVMe Win 10 boot drive, 500gb Samsung 840 EVO SSD, 512GB TeamGroup MP30 M.2 SATA III SSD, SuperTalent 512gb SATA III SSD, CoolerMaster HAF XM Case.
https://www.3dmark.com/3dm/37004594?
Daughter 2 Rig: ASUS B350-PRIME ATX, Ryzen 7 1700, Sapphire Nitro+ R9 Fury Tri-X, 16gb (2x8) 3200mhz V-Color Skywalker, ANTEC Earthwatts 750w PSU, MasterLiquid Lite 120 AIO cooler in Push/Pull config as rear exhaust, 250gb Samsung 850 Evo SSD, Patriot Burst 240gb SSD, Cougar MX330-X Case
https://linustechtips.com/topic/1225820-radiator-fans/#findComment-13851893
It tells you that a pricey Noctua fan makes the same noise as a 6-7€ fan running about 2000rpm through a heat sink. Are you basing your expectations of performance being different with a radiator on hype or some actual tests?
https://linustechtips.com/topic/1225820-radiator-fans/#findComment-13851904
I mean what he sent is not even the same fans as I mentioned I was thinking about buying so your point is kinda invalid
https://linustechtips.com/topic/1225820-radiator-fans/#findComment-13851913
https://linustechtips.com/topic/1225820-radiator-fans/#findComment-13851914
It's a different heat sink and will have a different effect on the noise, "50% fan" means literally nothing, and the test was designed to compare air coolers, not fans.
The best way to directly compare the fans would be to test them against each other running at the same RPM in open air, and on the same heatsink at the same noise level with the same heat load. AKA do science and actually control some variables.
The test as described cannot be used to compare the noise levels nor the performance of the fans.
My hypothesis is that a Noctua fan will perform better under a noise normalized test on the same heatsink, or will produce less noise at the same RPM, but I make no such claim since I'm too lazy to see if any such test has been performed. 🤣
The Arctic fans are fine and a good value from what I see others say.
The temperature of the liquid in your loop has a direct impact on the peak temps that you will get with your CPU. Every 1°C increase in fluid temp corresponds to 1°C increase in CPU temp. The fluid tends to take a while to heat up, so if you can run your fans a little faster when idle to prevent the fluid from heating up too much you'll see improvements in temps when under load. Ideally you would set up a fan curve based on the fluid temp, and you wouldn't get those sharp ramp ups and downs in fan speed.
From my experience its not too hard to setup a fan curve such that your fluid temp when idle is around 1°-3°C above ambient and under load is 7°-10°C above ambient.
BigBox (HTPC):
  • Display: None
  • 2.5Gb NIC
NAS:
  • Synology DS216J
https://linustechtips.com/topic/1225820-radiator-fans/#findComment-13851948
OMG thanks, I just looked at my fan control software and I can totally set it to fluid temp. Thats so cool thank you. Can you please tell me what should be optimal liquid temp? thanks a lot
https://linustechtips.com/topic/1225820-radiator-fans/#findComment-13851998
It really depends on your local ambient temps. In my experience, anywhere from 1°C to 15°C over ambient would be reasonable. So if it's 30°C where you are you might see temps between 31°C idle to 45°C under load.
Really, what you should do is monitor and get a feel for how your system performs. Find a max RPM that you are comfortable with the noise and see if that is sufficient to keep things cool, and then setup a fan curve that slowly ramps up to that speed as the fluid temp goes up.
Personally, I have my custom loop setup such that my fans start to get really audible around 36°C fluid temp and it never really gets over about 38°C. I have AC so my ambient air temps are like 22-26°C.
And for my wife's 280mm AIO I have it setup similarly. Her fluid never gets much above 37°C
BigBox (HTPC):
  • Display: None
  • 2.5Gb NIC
NAS:
  • Synology DS216J
https://linustechtips.com/topic/1225820-radiator-fans/#findComment-13852055
Its close enough. And its a slippery slope for you if you dont even read the test to see what 50% fan speed meant in rpm. Also if Noctua fans and coolers are so great, why is a 30-35€ Arctic Freezer 34 duo tied with the 100€ cooler in temps and noise?
https://linustechtips.com/topic/1225820-radiator-fans/#findComment-13855059
On 7/23/2020 at 2:11 PM, Korben said:
I would start with 3. 6 is still double the noise... and if you think of running 6 of  them at half speed.. they would probably still sound like 3 on a normal profile :) Just wasted money imo.
That's about as wrong as it's possible to be.
Correct would be the exact opposite of this.
I have 14 Noctua fans in my system. I can't hear any of them. They never have to ramp up, despite running a 9900K at 5.3GHz and a 980ti at 1530MHz.
Having lots of rad space and lots of fans is how quiet systems are made.
Loudest thing in my system is the D5 pump. Which runs at setting 2.
Also - can confirm Noctua A12 x 25s are way better than any other fan for performance  / noise.
9900K  / Asus Maximus Formula XI / 32Gb G.Skill RGB 4266mHz / 2TB Samsung 970 Evo Plus & 1TB Samsung 970 Evo / EVGA 3090 FTW3.
2 loops : XSPC EX240 + 2x RX360 (CPU + VRMs) / EK Supremacy Evo & RX480 + RX360 (GPU) / Optimus W/B. 2 x D5 pumps / EK Res
8x NF-A2x25s, 14 NF-F12s and a Corsair IQ 140 case fan / CM HAF Stacker 945 / Corsair AX 860i
LG 38GL950G & Asus ROG Swift PG278Q / Duckyshine 6 YOTR / Logitech G502 / Thrustmaster Warthog & TPR / Blue Yeti / Sennheiser HD599SE / Astro A40s
Valve Index, Knuckles & 2x Lighthouse V2
https://linustechtips.com/topic/1225820-radiator-fans/#findComment-13855178
  • 5 weeks later...
Yeah so I did a thing, bought 6 NOCTUA NF-A12x25-PWM and the difference is pretty jaw dropping for me, not even my AIO liquid temps went down from 36 to 30 C but overall those fans push way more air through system hence the whole system in cooler. My rams dropped about 15C on average :)
https://linustechtips.com/topic/1225820-radiator-fans/#findComment-13950261
  • 5 months later...
I see this is quite old, but i have to ask, do you use the fan as exhaust or intake on your radiator?
https://linustechtips.com/topic/1225820-radiator-fans/#findComment-14471875
