Budget (including currency): 300-500USD
Games, programs or workloads that it will be used for: Dolphin Emulator (4K ideally, but I definitely want to be able to run above native res), Garry's Mod (with lots of fairly demanding mods), TF2, GTA V, Unreal Tournament 2004, Unreal Tournament 4, potentially DooM 2016. I will be running Microsoft Visual Studio for programming, and for fun, I will be running VMware Workstation 10, likely with lots of VMs loaded up simultaneously with a decent chunk of resources allocated to them (providing I have them). I also am considering Hackintoshing this computer to run Final Cut Pro X for video editing
Monitors: One 1440x900, another 1280x1024 (plan to upgrade to 1600x1200 for my second display) -- I already have the two mentioned monitors
I have a few ideas as far as what this PC could be. One option is to take an old Dell Optiplex SFF (using Ivy Bridge or Haswell processors), and upgrade the RAM from 4-8GB to 16GB of DDR3, throw in a Crucial MX250 for storage (much of the storage, such as all the ISOs for VMs, and potentially the VHD's themselves, along with the Dolphin ISOs will be on my home server), potentially with a larger mechanical hard drive to replace the optical drive (I can use a USB drive whenever I need DVDs, and the computer may already come with a 500GB disk that I can zero-fill and use), put in a GTX 1650 Low Profile, or even a GT 1030 (I want some gaming muscle in a small package), and upgrade the i3/i5 to an i7 (probably not immediately, but down the line). Some HP SFF PCs would fit the bill as well, the point is, I'd be upgrading the hell out of an old prebuilt machine.
One thing to keep in mind is that while I'd like to have a SFF setup on top of my desk,
Another option is to try to build something using more recent components. Intel's processors (whether it be Skylake, Kaby Lake, or the more modern 8/9/10-series processors) seem more expensive than AMD's, and with the Ryzen daring to exist, not as good of a value. Even the more entry level Ryzen processors, while lacking hyperthreading (a useful feature for virtualization), have the GPU muscle that could allow me to abstain from a dedicated card, at least for a bit. To provide more details into my plans, here is a Google document: https://docs.google.com/document/d/1vqSV-Vatblqh5wETCwfsP8KEjhDqx2h7XUJXDe1j0-c/edit?usp=sharing with some of my thinking.
I am willing to entertain any and all suggestions for which planned build I should use, or if I should scrap what I've got and pick something completely different as far as parts.
https://linustechtips.com/topic/1225198-first-proper-pc-build-questions/
21 minutes ago, bmx6454 said:
if you could get the budget to say 700$+ you would be better off imo, as you could build a budget amd rig, with an rx580, that has room to be upgraded, where as the dell will be maxed out immediately.
I mean, the 330+ AMD rig I mentioned will be upgradable, but I do agree that the Dell is maxed out (short of potential new GPUs down the line, should better SFF-friendly models come out, and more storage). An increase to 700 would be tricky, but would certainly help. An RX580 does seem like a good card - substantially better performance than the 1650 Mini, but for roughly the same money. That increase would also buy me a Ryzen 5 3400G and maybe even a 3600X. However, assuming I can't afford the price hike, which option do you think is better - choosing the Dell, and getting more performance now for the same/less money, or paying more/the same money for less performance, but with more room to upgrade in the future (not necessarily to many more CPU generations, as I think AM4 is only good for one more, but potentially to a Ryzen 7 or something)?
if you plan on wanting/needing more power in the near future, i would go for the amd upgrade able path for sure. if you need something that can just get the bare minimum done now, and aren't worried about replacing it for more money down the road, maybe the dell.
edit: the psu i would change out(my psu knowledge isn't great) but otherwise, a build like this would have alot of upgrade potential, and good power now:
you could save 40$ on the cpu with a 3300x if you can find one.
After posting this, I put together a fairly similar system parts list, but for somewhat less money.spacer.pngI did note that a 3600 would yield better performance, and was an option. I see you mentioned an M.2 (and larger) solid state disk, which I suppose could be useful. I don't know, this is a tough decision - on the one hand, the Dell is powerful enough for me right now, and probably for a while longer, but on the other, it's kind of a "dead end" as a machine, and I'd just be delaying building a system like the Ryzen setup (just with another three or so years of technology under its belt). Overall, I think the Ryzen system is probably better for me, the difficult part now is narrowing down exactly what I'll want to buy.
One worry is that the motherboard wouldn't be compatible with a Zen 3 processor, so I'm considering opting for the (far less fast, but still screaming fast, and less expensive - basically identical price to the 3400G) Ryzen 5 2600.
