no post
powers there fans light come on ect everythings plugged in.
red "mem ok" lights on, hit it and it restarts and starts flashing?
red light under cpu comes on when restarts but goes off momentarily
gryphon motherboard
http://www.asus.com/Motherboards/GRYPHON_Z87/
https://linustechtips.com/topic/122509-no-post/
Hardware:  Seasonic 760watt platinum, 2x4gb of vengeance 1600mhz, 4670k
https://linustechtips.com/topic/122509-no-post/#findComment-1629959
A few things I can list off the top of my head:
  • Run 1 dimm at a time
  • Run with a backup known good dimm
  • Isolate your PSU short the single green and any 1 black cable with a paper clip. Power on and see if it shuts down.
  • Re-install your mobo checking to see if you've added an unnecessary standoff that may be causing a short
export PS1='\[\033[1;30m\]┌╼ \[\033[1;32m\]\u@\h\[\033[1;30m\] ╾╼ \[\033[0;34m\]\w\[\033[0;36m\]\n\[\033[1;30m\]└╼ \[\033[1;37m\]'
"All your threads are belong to /dev/null"
| 80's Terminal Keyboard Conversion | $5 Graphics Card Silence Mod Tutorial | 485KH/s R9 270X | The Smallest Ethernet Cable | Ass Pennies | My Screenfetch |
https://linustechtips.com/topic/122509-no-post/#findComment-1630025
It all powers up, it just doesn't post.   I think it's the CPU but not sure what to tell him to try.  He tried one dimm at a time, doesnt work.
https://linustechtips.com/topic/122509-no-post/#findComment-1630042
I had this issue during the summer, turned out to be a faulty hdd sector, sadly the sector which broke had part of windows startup on it so it panicked and looped never starting, try reinstalling windows about you have explored the above options.
Listen if you care.
https://linustechtips.com/topic/122509-no-post/#findComment-1630048
He hasn't installed windows yet, it does not post.
https://linustechtips.com/topic/122509-no-post/#findComment-1630050
First strip the motherboard off all pci and sata devices you don't need plugged in (run on integrated graphics if possible)
So here's a short list of possible issues if it still doesn't work:
1. Bad ram or ram slot (try different slot/ram configs)
2. Bad sata port (unplug all sata ports and try again)(I've seen a bad port break a bios when there is something plugged into it)
3. Bricked bios (if your motherboard has dual bios switch to the second bios,  should be a switch on the board if this is the case)
4. Bad processor (if you have another processor you can check with the system then its worth trying)
5. Chipset doesn't match the processor (if your mobo requires a certain bios revision for your processor then this could be the issue)
6. If you do have a GPU in a pcie slot then make sure there is power connected to it. (if you have integrated graphics take the GPU out)
7. You said the motherboard lights up so its getting power however the psu could still be an issue.  as a last ditch effort you could try a different psu.
As you can see there's alot of stuff that can cause this issue so you will just need to troubleshoot with whatever spare hardware you have.  the easiest way to be entirely sure its the motherboard if you don't have enough spare hardware around to swap stuff out would be to take a working motherboard out of one of your working machines and swap it into the system and see if it posts (assuming you have another mobo that supports the chipset).
Make sure you plug in a motherboard header speaker so you can hear it post if its a graphics issue.  Also I'm not sure if the motherboard has a debug led but if it does google the code it displays and see what you turn up.
Edited by Wolfereign
https://linustechtips.com/topic/122509-no-post/#findComment-1630052
Something like this happened on my build, turns out I just forgot to plug in one of the 6 pin power connectors on my graphics card.
Onboard graphics.
https://linustechtips.com/topic/122509-no-post/#findComment-1630066
didnt come w/ a speaker and theres no debug led
https://linustechtips.com/topic/122509-no-post/#findComment-1630085
@Wolfereign since he's retarded and doesn't give you the full details, I will. (he's on teamspeak with me)
When he boots the PC, EVERYTHING turns on, fans, leds on the motherboard, HDD, CPU fan.    There is just no video signal/ post.
He's using onboard graphics, and all the specs I posted in the second post.
I read the thread about no-post, he did not.
https://linustechtips.com/topic/122509-no-post/#findComment-1630092
It appears i havent fully awoke yet, ok so with an issue like this it mainly points to ram and motherboard, pretty much what bradcoolio said, unless its the unusual broken cpu which rarely happens(i never saw one with my own eyes) but broken cpus then to scramble words according to the research i did on them a while back. I wish i could be more helpful at any rate good luck and i hope you find the cause of the problem
Listen if you care.
https://linustechtips.com/topic/122509-no-post/#findComment-1630101
We need to know if the system posts or not.   Get a motherboard speaker or throw in a known working dedicated gpu to test (to rule out integrated graphics messing up).  Also even though the system powers up the PSU can still be the issue.   When it comes to no post you have to put in the time troubleshoot components.
https://linustechtips.com/topic/122509-no-post/#findComment-1630108
Ive tried the ram individually, what else could i do for the motherboard? or possibly the ram. i can grab some crappy ram from current walmart desktop and try it w/ those. or should i just try and rma the motherboard?
https://linustechtips.com/topic/122509-no-post/#findComment-1630113
I think you said before that there was no video output displaying, you can try another output if you wish but it seems like you could have a broken capacitor or a bad solder point, rma does seem like the logical choice however
Listen if you care.
https://linustechtips.com/topic/122509-no-post/#findComment-1630118
He tried HDMI first, that didn't work so he tried DVI and that didn't either.   Could it be the CPU?  When he installed it, I told him to take a picture first and the triangles were lined up+ so were the 2 nothces, so I'm assuming it didn't get messed up or something.
https://linustechtips.com/topic/122509-no-post/#findComment-1630197
i doubt its the cpu, its very very uncommon for a broken cpu to be well broken, my guess is that its the motherboard.
Listen if you care.
https://linustechtips.com/topic/122509-no-post/#findComment-1630202
He did put it together on his bed.. I don't think he statically discharged on anything, but idk.
He mentioned going to tigerdirect tomorrow and buying a mobo speaker, should give more insight.
https://linustechtips.com/topic/122509-no-post/#findComment-1630212
Fucking idiotic, hes fried that board definitely, you can get charges very easily from the bed due to the material its made out of, he might of well made it on a carpet. yeah thats the problem, he screwed up and now he is paying the price, rma the board and dont tell the company that it is his fault, juts say doa and you are good to go.
Listen if you care.
https://linustechtips.com/topic/122509-no-post/#findComment-1630240
If the board was fried would it even start up the system? Or would that be why it's not posting?
And yeah, he posted a pic and I could see cloth-like substance behind the screw holes, and I asked "what's it on...?"
"My bed"
FACEPALM.
https://linustechtips.com/topic/122509-no-post/#findComment-1630254
"My bed"
FACEPALM.
Depending on what is fried the answer is yes and no, doesnt he have a kitchen table or something, honestly thats just stupid, ive built a crazy amount of pcs in my time and never did anything so stupid god im shocked, static is the first thing you should know about. also dont fall into the trap of getting a strap they are completely pointless in all situations.
Listen if you care.
https://linustechtips.com/topic/122509-no-post/#findComment-1630261
I've done stuff whilst standing on my carpet before, but I always make sure to ground myself before touching things.    (Common sense,  electronics+ static= bad)
https://linustechtips.com/topic/122509-no-post/#findComment-1630264
A carpet is better then a bed, hell at least put it on the anti static bag, that bag isnt the best surface but regarding antistatic issues its miles ahead, if you dont like that then use the box that the motherboard came in, ive always used that box(i put the bag on top if its dusty), then touch the case whenever you take out a new product, touch the case if you scratch yourself especially your hair.
Listen if you care.
https://linustechtips.com/topic/122509-no-post/#findComment-1630278
Exactly, I gave him so many guides on everything and he was all like "yeah you said it's easy i'll just do it"   then he asks 50000 questions that the guides would of answered -.-
https://linustechtips.com/topic/122509-no-post/#findComment-1630302
