9 minutes ago, sczze said:
hi guys is there any software that allows me to see like the total power draw from the laptop charging adapter?
and oso does the charging adapter have a temperature sensor in it?
A watt meter you can plug into the wall and have your laptop charger plug into it.  For temps not really, don't think any adapter has a built-in temp sensor.
QUOTE ME IN A REPLY SO I CAN SEE THE NOTIFICATION!
When there is no danger of failure there is no pleasure in success.
https://linustechtips.com/topic/1224938-charging-adpter-info/#findComment-13844703
this only shows power that adaptor draw adaptor efficiency isn included and  that efficiency is not constant
if it was useful give it a like :) btw if your into linux pay a visit here
https://linustechtips.com/topic/1224938-charging-adpter-info/#findComment-13844709
Of course, but OP seems to only want to see how much he's drawing, which this will do.
https://linustechtips.com/topic/1224938-charging-adpter-info/#findComment-13844712
Actually, the watt-meter in the picture does show voltage, power-draw and power-factor. "Efficiency" is a function of voltage, power-draw and power-factor, so this meter is actually really good. I have one myself.
https://linustechtips.com/topic/1224938-charging-adpter-info/#findComment-13844715
sort of these thing dont calculate power factor stuff that a lot of SMPSs have
https://linustechtips.com/topic/1224938-charging-adpter-info/#findComment-13844717
I doubt OP is doing this needing such exacting accuracy.
https://linustechtips.com/topic/1224938-charging-adpter-info/#findComment-13844720
Quote
its not accuracy power factor stuff  in smps isnt like other thing adopters current draw isnt a sine wave (as with other things) it will make calculating thing complecated
https://linustechtips.com/topic/1224938-charging-adpter-info/#findComment-13844726
