I just got ek’s new aio 360 d rgb. I had the pump plugged into the cpu opt header on my x570 aorus master motherboard. I accidentally unplugged the pump while the pc was turned on and now the pump wont work and my cpu temps are at 90 degrees. Help pls
https://linustechtips.com/topic/1224839-aio-pump/
Well, Clear CMOS and then plug it back in, then, or use a different port.  Why did you unplug it with the power on?  Hope you didn't destroy the pump.
https://linustechtips.com/topic/1224839-aio-pump/#findComment-13846726
