7 minutes ago, Giggles94 said:
I'm a complete noob setting up a New PC but every time I connect DP cable to graphics card and monitor i get stuck on HDMI 1 no signal and changing it to DP input just makes the monitor go into standby mode
Go into the monitor OSD & set the input detect to Auto, with no cable attached.
The monitor is currently expecting a signal in HDMI 1 port & not getting one...
**I frequently edit any posts you may quote; please check for anything I 'may' have amended.**
Current PC spec. in my profile.
Can I realistically call myself a gamer, if I only play ONE, twenty year old game...?
Did you test boot it, before you built in into the case?
WHY NOT...?!
8 minutes ago, Giggles94 said:
I connected my laptop to the monitor so it would allow me to change it to DP input but just changes straight back HDMI
Did you adjust the OSD with NO cable attached?
The other option is that the DP cable is dead.
WHY NOT...?!
