Hey guys i just saw the Tek syndicates video about VPN and how it can give you a better experience if you use a VPN for watching Netflix and stuff but i don't want to buy a VPN yet so i was wondering is there any good free VPN Solution that i can try and then if i like it buy it ? also what is the best VPN solution PAID. Thanks for everyone who helps (:
https://linustechtips.com/topic/122306-best-vpn-solution/
Two questions just to be sure.
1) When you say better experience what is it you are after?
2) Do you know what a VPN is?
|| Processor: AMD Ryzen 5 2600 || RAM: 32GB (4x8GB) Corsair DDR4 Vengance (3000) || Motherboard: ASUS Prime B450-Plus || Graphics Card: Gigabyte RTX2070 || Storage: 750GB SSD (2 Drives), 3TB HDD (2 Drives) || Case: NZXT H500 || Power Supply: be quiet! Pure Power 11 600W ||
https://linustechtips.com/topic/122306-best-vpn-solution/#findComment-1627383
Try hotspot shield.
CPU : Intel Core i7 3960X, Mobo : X79-UD3, Memory : 4x4GB Vengeance Black Memory 1600MHz, GPU : Asus GTX 970 Strix, Case : Switch 810 Matte Black, Storage : 256GB Samsung 830 SSD, Seagate Barracuda 1TB, PSU : Thermaltake 750W 80+ Bronze, Displays : 3x Asus 1080p Screens, Cooling : Corsair H100i, Keyboard : Logitech G710+, Mouse : Madcat Cyborg R.A.T.7, Sound : Sennheiser HD598, V-Moda Crossfade LP, Logitech Z-5500, HMD : Oculus Rift CV1
https://linustechtips.com/topic/122306-best-vpn-solution/#findComment-1627384
smoother while streaming i have 30/5 internet and it still buffers
That is not what a VPN does. A VPN would make that worse.
To put it simple a VPN allows your internet connection to appear elsewhere in the world so in the case of Netflix you can watch US shows in the UK by using a VPN that makes you appear in the US. But they tend to slow down your connection.
https://linustechtips.com/topic/122306-best-vpn-solution/#findComment-1627413
watch this video please (:
https://linustechtips.com/topic/122306-best-vpn-solution/#findComment-1627457
That is very circumstantial. VPNs add a LOT of overhead to your traffic.
https://linustechtips.com/topic/122306-best-vpn-solution/#findComment-1627525
We need new network Icontrol.
So you run VPN when running bandwith apps.
And direct line when running Latency sensitive apps.
CPU: Ryzen 5500 GPU: RX 6800 RAM: DDR4 3200MHZ 48GB (2x8+2x16 GB)  MOBO: MSI B450-A PRO Display: 4k120hz with freesync premium.
https://linustechtips.com/topic/122306-best-vpn-solution/#findComment-1628566
