Hey there. IIRC, there isn't an option to delete individual PCs/cases once spawned, but there are some workarounds:
  • Store the PC in the cabinet. Out of sight, out of mind. It will still exist in the cabinet, however.
  • Reset the Free Build workshop from the ESC menu. The workshop will return to its default state.
  • Strip the PC of all parts, then pick up the case, and go to the Inventory/the shelf. Select the desired case for your PC build. Once selected, the old case in your hands should be replaced with the new case.
正直に生きる、一度きりの人生だから
Keeb Weeb LinksCustom Mechanical Keyboards | #KeebWeebClub
'Chew Builds: Hoshī (PC) | Okashī (PC) | K-4398 (Keeb) | Eighty #391 (Keeb) | R2-968 (Keeb) | MGK64 (Keeb)
https://linustechtips.com/topic/1222809-pc-building-simulator/#findComment-13827690
