Urgent Advice required.
By
SagarBajpai
in Power Supplies
in Power Supplies
Solved by Guest,
RX570 is a pretty decent card. Not something I would want to run on that PSU.
You should be fine for a while (other than some BSODs, shut downs and other crashes), but the PSU shouldn't actually "damage" your graphics card.
MadManMarsBar ·
Posted in Build Logs0 -
IAmAndre ·
Posted in New Builds and Planning3 -
4
2
Playgb2 ·
Posted in Troubleshooting1 -
1
1
5
1
play_circle_filled
Latest From ShortCircuit:
