so im a water cooling noob.  Ive decided to take apart my system and clean it out.  While doing that i decieded to try and move the rads around mostly to help make my pump the lowest point in my loop.  My question is i wana make a run from my top rad to my front rad.  The issue is that since im using soft tubing, im afraid that it will kink with the type of bend that i need to make.  I will attach a picture of where it is going into.  Do they make right angle fittings for soft tubing?  If they do could you link some to me.  Im trying to stick with ekwb just because everything else is that and they have to be black to match the rest of the system.  If ekwb dosent make them, then please let me know who makes them.  If i am just talking nonsense and this part dosent exist, also let me know.  Thanks
Current Rig=  AMD Ryzen 9 5900x, Asus Crosshair Hero VIII, EVGA RTX 3070 FTW3 ultra, 32gb Corsair Vengence Pro RGB 3000hz White, EVGA 750 P2 PSU, 1TB Samsung 980 Pro, 500gb samsung 860 evo, 250GB Samsung 850 evo, 2TB Samsung 970 Evo Plus, 2TB seagate firecuda sshd,  LianLi PC 011 Dynamic XL ROG edition, Corsair h150i elite capelix
https://linustechtips.com/topic/1222200-what-fitting-do-i-need/
Search ebay for G1/4 fittings.
https://www.ebay.com/sch/i.html?_from=R40&_trksid=p2380057.m570.l1313.TR2.TRC1.A0.H0.XG1%2F4+90+degree+fitting.TRS0&_nkw=G1%2F4+90+degree+fitting&_sacat=0
Thats just an example, there are a ton of G1/4 EK fittings in black that you can find in that search but boy...what a price to pay for a piece of metal for a brand name on it.
Workstation Laptop: Dell Precision 7540, Xeon E-2276M, 32gb DDR4, Quadro T2000 GPU, 4k display
Wifes Rig: ASRock B550m Riptide, Ryzen 5 5600X, Sapphire Nitro+ RX 6700 XT, 16gb (2x8) 3600mhz V-Color Skywalker RAM, ARESGAME AGS 850w PSU, 1tb WD Black SN750, 500gb Crucial m.2, DIYPC MA01-G case
My Rig: ASRock B450m Pro4, Ryzen 5 3600, ARESGAME River 5 CPU cooler, EVGA RTX 2060 KO, 16gb (2x8) 3600mhz TeamGroup T-Force RAM, ARESGAME AGV750w PSU, 1tb WD Black SN750 NVMe Win 10 boot drive, 3tb Hitachi 7200 RPM HDD, Fractal Design Focus G Mini custom painted.
NVIDIA GeForce RTX 2060 video card benchmark result - AMD Ryzen 5 3600,ASRock B450M Pro4 (3dmark.com)
Daughter 1 Rig: ASrock B450 Pro4, Ryzen 7 1700 @ 4.2ghz all core 1.4vCore, AMD R9 Fury X w/ Swiftech KOMODO waterblock, Custom Loop 2x240mm + 1x120mm radiators in push/pull 16gb (2x8) Patriot Viper CL14 2666mhz RAM, Corsair HX850 PSU, 250gb Samsun 960 EVO NVMe Win 10 boot drive, 500gb Samsung 840 EVO SSD, 512GB TeamGroup MP30 M.2 SATA III SSD, SuperTalent 512gb SATA III SSD, CoolerMaster HAF XM Case.
https://www.3dmark.com/3dm/37004594?
Daughter 2 Rig: ASUS B350-PRIME ATX, Ryzen 7 1700, Sapphire Nitro+ R9 Fury Tri-X, 16gb (2x8) 3200mhz V-Color Skywalker, ANTEC Earthwatts 750w PSU, MasterLiquid Lite 120 AIO cooler in Push/Pull config as rear exhaust, 250gb Samsung 850 Evo SSD, Patriot Burst 240gb SSD, Cougar MX330-X Case
https://linustechtips.com/topic/1222200-what-fitting-do-i-need/#findComment-13822694
Its not quite that simple. Yes they do right angle connectors for soft tubing but they do come in different sizes. That looks like a standard G1/4 fitting from the pic but there's no way we can say that for sure. You need to measure the OD & ID of the pipe to make sure.
TBF the vast majority of soft tubing equipment uses G1/4 so its very likely to be that but its also not exactly cheap to buy a new fitting that might end up being wrong.
Main Rig:-
Server:-
https://linustechtips.com/topic/1222200-what-fitting-do-i-need/#findComment-13822696
As long as you have a res, the pump just needs to be bellow that. It doesn't have the be the lowest point in the loop. The res is what helps collect air, and thus only allows the pump to be fed 100% water.
As far as adapters, I typically use swivel 25's or 90's. The far left is what I have a few of, but, you get the idea.
EK-AF Angled 90° G1/4 Nickel
https://linustechtips.com/topic/1222200-what-fitting-do-i-need/#findComment-13822726
