I accidentally deleted some files off of one of my SSDs a lil while ago, but i have the files i need on a different hard drive, but they're all in different folders, is there a program on windows 10 that can move files from multiple folders at once instead of having to manually move each file one by one?
Edited by Goku1814
https://linustechtips.com/topic/1221635-faster-way/
I like FreeFileSync. It will take you a while to program though if you're looking to copy specific files to a single or different destinations but it's doable.
https://linustechtips.com/topic/1221635-faster-way/#findComment-13818192
