Hey guys, I'm freeing up some space on my hard drive and I found out that I have an Nvidia folder and inside are some drivers like 310.90, 313.96, 320.49 and so on, can I delete them or leave them there?
ASUS ROG G75VX
Intel i7-3630QM 2.4GHz/3.4GHz Turbo | Nvidia GeForce 670MX 3GB OCed to 736MHz | 750GB HDD | Windows 8.1 | 24 GB 1600MHz RAM | Razer Goliathus Medium | Logitech G400s | Razer Kraken/ JBL J22 | Corsair Vengeance K70 Cherry MX blue
https://linustechtips.com/topic/122145-need-some-help-with-nvidia-drivers/
yes, you can delete them.
every time you download new drivers, all data is beeing unpacked to the C:\Nvidia folder and installed from there. So its essentially just a kind of cache between the downloaded file and driver installation.
I just normally keep the latest non-beta drvers in case beta doesnt work properly, so I dont need to download and unpack it again.
Personal Build Project "Rained-On"
helped building up the CPU Overclocking Database and GPU Overclocking Database, check them out ;)
#KilledMyWife #MakeBombs #LinusIsNotFunny || Please, dont use non-default grey font colors. Think about the night-theme users! ;)
Ok, so delete pretty much all except latest one?
ASUS ROG G75VX
yes
