13 minutes ago, mahyar said:
are you sure that problem is with your drive
The problem is already fixed. I went to take a look at what drive I exactly have and the power cable was out. I haven't moved the rig in months and the problem started a few days ago...
So everything is good!
https://linustechtips.com/topic/1221092-drive-not-working/#findComment-13813217
If the power wasn't connected you either wouldn't see the drive at all that you were just trying to write to or Windows wouldn't boot at all so I think you're talking about two very unrelated things. Unless you mean't the SATA data cable. That could be related then if it appeared loose, or not fully seated.
https://linustechtips.com/topic/1221092-drive-not-working/#findComment-13815797
