Hi, bought new pc. Have 30fps in game(cod wz), tried cs:go 50-60fps. What i tried: 1. hmdi cable in gpu slot 2. reinstalled graphic drivers 3. display settings 144hz 4. motherboard doesnt have interrogated gpu 5. nvidia control panel also didnt help 6. BIOS updated 7. Using 1 monitor Specs Ryzen 36000, RTX 2070Super, 16GB 3200MHZ, Corsair TX850m: Monitor Samsung cjg50 On Stress test programs (occt, msi afterburner) seems everything normal. Temperatures, usage gpu, cpu also normal. In game seems like gpu doesnt work 100%. Please help
https://linustechtips.com/topic/1221039-strange-issue-fps/
If you activate Nvidia DSR some games startup at 4K 2160p resolution.
What INGame resolution and detail settings have you got setup?
Maximums - Asus Z97-K /w i5 4690 Bclk @106.9Mhz * x39 = 4.17Ghz, 8GB of 2600Mhz DDR3,.. Gigabyte GTX970 G1-Gaming @ 1550Mhz
https://linustechtips.com/topic/1221039-strange-issue-fps/#findComment-13812838
Can you confirm the games not using igpu? sounds way too low fps to be throttle.
main rig:
CPU: 8086k @ 4.00ghz-4.3 boost
PSU: 750 watt psu gold (Corsair rm750)
gpu:axle p106-100 6gbz msi p104-100 @ 1887+150mhz oc gpu clock, 10,012 memory clock*2(sli?) on prime w coffee lake igpu
Mobo: Z390 taichi ultimate
Ram: 2x8gb corsair vengence lpx @3000mhz speed
case: focus G black
OS: ubuntu 16.04.6, and umix 20.04
Cooler: mugen 5 rev b,
Storage: 860 evo 1tb/ 120 gb corsair force nvme 500
backup
8gb ram celeron laptop/860 evo 500gb
https://linustechtips.com/topic/1221039-strange-issue-fps/#findComment-13812851
7 minutes ago, g1ntas256 said:
hi, 2560x1440 csgo  ; COD 1920x1080. How to know render scale. Settings high. DSR off
render scale doe not matter right now try using ddu (display driver uninstaller) i know you said you removed drivers before but this will purge old driver
if it was useful give it a like :) btw if your into linux pay a visit here
https://linustechtips.com/topic/1221039-strange-issue-fps/#findComment-13812859
the 3600 doesnt have a igpu
G502 Lightspeed Review
PC:
i5-6400
GIGABYTE GA-H110M-DS2
CORSAIR VENGEANCE LPX 2X4 DDR4-2666MHz
ASUS ROG STRIX-GTX 1060-O6G
SEAGATE 2TB HDD
FUJISTU F300 240GB SSD
CORSAIR CX750M
Laptop:
Acer Nitro 5
i5 8300h
GTX 1050 4Gb
12 Gb RAM
128 Gb SSD
1 Tb HDD
Peripherals:
Keyboard:
Logitech G310 Atlas Dawn (Romer G)
Rexus Legionare MX5.1 (Content Browns)
Mice:
Logitech G602
Logitech G502 Lightspeed
Steelseries Rival 105
Logitech M330
Headset:
Logitech G430
Cooler Master MH 752
https://linustechtips.com/topic/1221039-strange-issue-fps/#findComment-13812866
did you try this?
https://linustechtips.com/topic/1221039-strange-issue-fps/#findComment-13812887
does the board have a diffrent pcie slot you can try?
main rig:
case: focus G black
backup
https://linustechtips.com/topic/1221039-strange-issue-fps/#findComment-13815170
