I am trying to install Windows on my mobo but I have a feeling that the port (HDMI) on the back of it is dead. My monitor can not receive a signal from it.  I know the port on my monitor is good and the cable I used is good as well. What's left is the port on the board right? So I have to assume that the port is dead?
https://linustechtips.com/topic/1220884-need-another-mobo/
What CPU are you using?
Do you have a dedicated GPU?
https://linustechtips.com/topic/1220884-need-another-mobo/#findComment-13811475
Specs?
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1220884-need-another-mobo/#findComment-13811482
If you're using a GPU, is the monitor plugged into that?
**I frequently edit any posts you may quote; please check for anything I 'may' have amended.**
Current PC spec. in my profile.
Can I realistically call myself a gamer, if I only play ONE, twenty year old game...?
Did you test boot it, before you built in into the case?
WHY NOT...?!
https://linustechtips.com/topic/1220884-need-another-mobo/#findComment-13811483
1 minute ago, TofuHaroto said:
Specs?
Yes; can't type w/o them.  :D
WHY NOT...?!
https://linustechtips.com/topic/1220884-need-another-mobo/#findComment-13811487
I'm seriously mad at my self for not understanding what you mean lol.
Build Log:
https://linustechtips.com/topic/1220884-need-another-mobo/#findComment-13811491
Spectacles...  :)
WHY NOT...?!
https://linustechtips.com/topic/1220884-need-another-mobo/#findComment-13811493
