wird driver problems.
Go to solution Solved by Benjio,
http://support.asus.com/download.aspx?SLanguage=en&m=Rampage+IV+Extreme&os=30
There you go, scroll down and expand the audio section, the top one should be the latest. Also make sure to change it to the correct OS on top.
Greetings techies. so ive been looking throught aheap of files and i just cant find the onboard audio drivers.
I have the Razer tiamat 7,1 wich iknow doesnt have drivers but the onboard drivers for my motherboard are installed i just cant find them, there is some weird error that causes poor quality and dropout etc.
so i figured out i have to reinstall. anyone have a clue where these are located or even named :P ?.
Mobo: Asus rampage iv extreme
Thanks!
https://linustechtips.com/topic/122081-wird-driver-problems/
sweet, thanks! didnt think of that at all
https://linustechtips.com/topic/122081-wird-driver-problems/#findComment-1625077
