Ethernet cable?
Solved by Dedayog,
2 minutes ago, Amer said:What do you think about this? Cat 6 Ethernet Cable 50 ft White - Flat Internet Network Lan patch cords – Solid Cat6 High Speed Computer wire With clips& Snagless Rj45 Connectors for Router, modem – faster than Cat5e/Cat5 - 50 feet https://www.amazon.com/dp/B00WD017GQ/ref=cm_sw_r_cp_api_i_KLDcFbSAK0RR2
Perfect, I use the same but at 100ft. Gives me my full Gigabit connection.
