Youtube problems.
30 minutes ago, RKC said:I just want to know if this is the fault of my machine of my ISP because on my phone I can watch HD vids in youtube. In my laptop I can watch twitch perfectly but its only youtube that really has a problem. My ISP provider didnt help me at all.
If you're watching HD vids on your phone over LTE, then your wireless ISP has working IPv6. If you can get the phone to work on your WiFi but your PC will not (wired or wireless) to the same router, then that's a configuration problem on your PC. If both do not work over wifi/wired to the router, then the problem is the router or ISP.
My opinion, and this is based entirely on my own experience is that it's usually misconfigured CPE (Customer Premises Equipment), by which if you have another router somewhere on your network previously had a ipv6 tunnel setup before. This is why I asked you to run ipconfig to see what it's set to. If the network adapter has a "real" IPv6 address assigned, but it doesn't reach anything, then that's why you're experiencing this, but it can also be that it's trying to reach something using the self-assigned link-local address, and is requesting ipv6 AAAA records from the DNS rather than A records for ipv4.
So the simplest solution is to turn off IPV6. You can check your mobile phone to see what ip address it has (just go to "what is my ip address" in google, if it says you're on a ipv6, then you're on v6. if it only shows v4, then you're on v4. Then compare the mobile to your fiber connection.
