Is that 80 C under idle? When gaming? When running Prime 95?
CPU i7 14700K | CPU Cooler Noctua NH-U12A | Motherboard MSI Pro Z690-A | GPU Zotac Airo RTX 4080 | RAM 32 GB GSkill Ripjaws V 4400
Mhz |
 Monitor Alienware AW2721D / Gigabyte M28U | PSU ASUS ROG Strix 850G
https://linustechtips.com/topic/1220503-cpu-heat/#findComment-13808447
Not sure about this CPU but this does seems kind of high for just gaming. Maybe someone who has experience with this CPU can provide more information.
Mhz |
https://linustechtips.com/topic/1220503-cpu-heat/#findComment-13808476
So for some reason AMD doesn't even list the max safe temperature on their website for the 3300x, but if it's anything like literally any Zen 2 chip on the market, the TJMax is 95C.
If that's correct and you're at 80C, you're well within the safe temperature range, though cooler is always better. You could always try to remount your cooler to see if that's an issue. That's a lot of heat for a 4c CPU.
A side note, if anyone tells you 80C is good (or any temperature for that matter) without knowing the hardware/cooler/specific circumstance that they're talking about, I'd say ignore literally any tech advice they have to offer.
Gaming Build:
CPU: Ryzen 7 3800x   |  GPU: Asus ROG STRIX 2080 SUPER Advanced (2115Mhz Core | 9251Mhz Memory) |  Motherboard: Asus X570 TUF GAMING-PLUS  |  RAM: G.Skill Ripjaws DDR4 3600MHz 16GB  |  PSU: Corsair RM850x  |  Storage: 1TB ADATA XPG SX8200 Pro, 250GB Samsung 840 Evo, 500GB Samsung 840 Evo  |  Cooler: Corsair H115i Pro XT  |  Case: Lian Li PC-O11
Peripherals:
Monitor: LG 34GK950F  |  Sound: Sennheiser HD 598  |  Mic: Blue Yeti  |  Keyboard: Corsair K95 RGB Platinum  |  Mouse: Logitech G502
Laptop:
Asus ROG Zephryus G15
Ryzen 7 4800HS, GTX1660Ti, 16GB DDR4 3200Mhz, 512GB nVME, 144hz
NAS:
QNAP TS-451
6TB Ironwolf Pro
https://linustechtips.com/topic/1220503-cpu-heat/#findComment-13808507
