9 minutes ago, hbsterling said:
My first time installing Freenas and after loading, it says "The web interface could not be accessed." I checked and my router is set up for DCHP. How I can fix this issue?
Where did it say that? That sounds like something your browser would be telling you, not the monitor plugged into your Freenas box... The freenas "head" looks like this
That is my FreeNas "monitor". I run it in a VM under ESXi, that show I pulled a screenshot of it.
What is your FreeNAS IP address? Your putting that into your browser, (use HTTPS, not sure why mine even has an http option.... going to have to disable that, didn't used to be enabled, very strange) and getting that error?
2 minutes ago, LIGISTX said:
Where did it say that? That sounds like something your browser would be telling you, not the monitor plugged into your Freenas box... The freenas "head" looks like this:image.png.61bc1d76154c0db7b1a901621e7f236a.png
After Freenas loads it does not show an ip address, after 11) shutdown it says the web interface cannot be accessed. I checked all the connections and restarted but no luck.
Ah. What motherboard are you using? Its possible it doesn't have a driver for the NIC your mobo has... I am personally now sure how you would go about adding a custom driver either. You could try and go into configure network interfaces and see what shows up? I assume nothing will though...
If you can't get it working on the NIC built into your mobo, a Intel 2 plug gigabit PCIe card is pretty cheap:
 https://www.ebay.com/itm/IBM-INTEL-PRO-1000-PT-QUAD-PORT-PCIe-GIGABIT-NIC-HBA-SERVER-ADAPTER-CARD-39Y6138/142107635897?_trkparms=aid%3D1110012%26algo%3DSPLICE.SOIPOST%26ao%3D1%26asc%3D225086%26meid%3Dae7865e72ca74512b49a2f4e3803fe24%26pid%3D100008%26rk%3D3%26rkt%3D12%26mehot%3Dpp%26sd%3D132894233850%26itm%3D142107635897%26pmt%3D1%26noa%3D0%26pg%3D2047675%26algv%3DPromotedSellersOtherItemsV2%26brand%3DUnbranded&_trksid=p2047675.c100008.m2219
Well thats an uugly URL lol. But any Intel NIC would work.
I am using an asrock h470m-itx/ac. If it is not compatible what other OS would you recommend to use?
Looks like your NIC is Dragon RTL8125BG... whatever that is. Its a realtech chip, which is almost certainly the issue.
What is your intended purpose? Hard to recommend a file server OS with no info...
But with that said, I am not sure what others would have a driver for that either. You may end up having to get a PCIe NIC regardless, or go forum searching for how to load a driver. Although, I bet most responses will be "just get an Intel NIC, there is a reason they are the standard for gigabit networking".
I am just using it for a Plex server
What hardware, as far as storage. If its literally just a plex server, you could just run Windows....
Just now, hbsterling said:
3 Segate 6tb drives, I might just have to run windows then
With only 3 drives, FreeNAS is sort of a lot of work for no real "point". Are you planning on running some version of RAID? All you can do with that is RAID 5 ( I mean, you could RAID 0.... but like, don't). You would try unraid as your OS, it *may* have support for that NIC.
But again, these OS's are really geared more towards a more "advanced" user. Its not easy to add drives to freenas, although it is easier to add to unraid (as unraid doesn't use standard RAID, thus its name).
Yeah I was going to run raid 5
I assume the mobo has RAID 5 support in hardware, or could get a little boot SSD for cheap, run windows on that (you would need a boot device separate from the 6TB drives for any of these options anyways) and set up, uh, i forget what its called but windows has a way to do it.
Just, remember. RAID 5 "is dead". But, since its low importance data like movies and tv shows, its fine.
Basically, statistically speaking you likely will run into a flipped bit as you rebuild an array that only has single redundancy since our drives today are so large... Also, you run the risk of a second drive failing during the rebuild. Obviously, these are low risk and low impact for your use case. If a bit is flipped, likely nothing will matter since its a video file. And the chance of a second drive failing isn't very high in the realm of all possible things that can happen.
But this is why I run RAID Z2 (ZFS equivalent of RAID 6).
Have you got the LAN cable plugged into the intel gigabit LAN? rather than the 2.5G dragon port?
Please quote my post, or put @paddy-stone if you want me to respond to you.
  • PCs:-
  • Main PC build  https://uk.pcpartpicker.com/list/2K6Q7X
  • ASUS x53e  - i7 2670QM / Sony BD writer x8 / Win 10, Elemetary OS, Ubuntu/ Samsung 830 SSD
  • Lenovo G50 - 8Gb RAM - Samsung 860 Evo 250GB SSD - DVD writer
  • Displays:-
  • Philips 55 OLED 754 model
  • Panasonic 55" 4k TV
  • LG 29" Ultrawide
  • Philips 24" 1080p monitor as backup
  • Storage/NAS/Servers:-
  • ESXI/test build  https://uk.pcpartpicker.com/list/4wyR9G
  • Main Server https://uk.pcpartpicker.com/list/3Qftyk
  • Backup server - HP Proliant Gen 8 4 bay NAS running FreeNAS ZFS striped 3x3TiB WD reds
  • HP ProLiant G6 Server SE316M1 Twin Hex Core Intel Xeon E5645 2.40GHz 48GB RAM
  • Gaming/Tablets etc:-
  • Xbox One S 500GB + 2TB HDD
  • PS4
  • Nvidia Shield TV
  • Xiaomi/Pocafone F2 pro 8GB/256GB
  • Xiaomi Redmi Note 4
  • Unused Hardware currently :-
  • 4670K MSI mobo 16GB ram
  • i7 6700K  b250 mobo
  • Zotac GTX 1060 6GB Amp! edition
  • Zotac GTX 1050 mini
1 hour ago, hbsterling said:
I tried both, I decided to switch to Windows
You didn't consider Linux, being the next closest to FreeNAS?
It supports ZFS (ZoL / ZFSonLinux), if you don't mind using the command line, at least for configuring the array.
There is a ZFS Manager for Cockpit as well which gives you a GUI https://github.com/optimans/cockpit-zfs-manager
I haven't tried it since early Alpha which had a lot of problems but its had a few updates since then so might be worth trying out
Desktop: Ryzen9 5950X | ASUS ROG Crosshair VIII Hero (Wifi) | EVGA RTX 3080Ti FTW3 | 32GB (2x16GB) Corsair Dominator Platinum RGB Pro 3600Mhz | EKWB EK-AIO 360D-RGB | EKWB EK-Vardar RGB Fans | 1TB Samsung 980 Pro, 4TB Samsung 980 Pro | Corsair 5000D Airflow | Corsair HX850 Platinum PSU | Asus ROG 42" OLED PG42UQ + LG 32" 32GK850G Monitor | Roccat Vulcan TKL Pro Keyboard | Logitech G Pro X Superlight  | MicroLab Solo 7C Speakers | Audio-Technica ATH-M50xBT2 LE Headphones | TC-Helicon GoXLR | Audio-Technica AT2035 | LTT Desk Mat | XBOX-X Controller | Windows 11 Pro
Server: Fractal Design Define R6 | Ryzen 3950x | ASRock X570 Taichi | Asus RTX 4060 Dual OC | 64GB (4x16GB) Corsair Vengeance LPX 3000Mhz | Corsair RM850v2 PSU | Fractal S36 Triple AIO + 4 Additional Venturi 120mm Fans | 8 x 20TB Seagate Exos X22 | 4 x 16TB Seagate Exos X18 | 3 x 2TB Samsung 970 Evo Plus NVMe | LSI 9211-8i HBA
NAS: Innovision 4U 24-bay chassis (12GB MiniHD SGIO Backplane) | Intel Core i9-10980xe | EVGA X299 FTW-K | EVGA RTX 2080Ti Super FTW3 | 128GB (8x16GB) Corsair Vengeance LPX 3200Mhz | DEEPCOOL PN1000M PSU| Noctua NH-D12L Chromax Black | 16 x 16TB Seagate Exos X18 | 2 x 2TB Samsung 990 Pro | 2 x 2TB Intel U.2 P4510 | LSI 9305-24i HBA
