Coin Mining network question.
Go to solution Solved by Mentalguy,
Found a Program. thanks for trying those that did.
mine is normally less that 1kbs
If youre already running it, why not measure it with iftop or vnstat?
task manager>performance>resource monitor
@Riddler356
My Rig :  Case: Cooler Master HAF X ,Motherboard: Gigabyte Z87X-UD3H,PSU: Seasonic SS-750KM3,Processor: Core I7 4770k (overclocked 4.7ghz),Cooler: Corsair H100i, GPU: EVGA GTX 780 with acx cooler, RAM: G.Skill Ripjaws 16gb DDR3 1600 (overclocked to 2000mhz), HDDS  Samsung 840 EVO 250 gb SSD , Western digital  2tb 7200 rpm 64mb cache, Old 1tb laptop drive I had , 320gb for os backup daily, 80gb external for weekly backups,Drives 2x Lg Blu Ray burner WH16MS40,MISC: Tp-Link dual band wireless card, Logitech g510s, Razer Deathadder 2013, Acer G236HLBbd 23" monitor, Old tv I had 23" for secondary monitor, old 32" samsung tv third monitor
I know about the resource monitor, but I don't want to have to watch it constantly to know how much I am uploading.
what are those programs, never heard of them before.
Nothing to see here, move along
you had a better answer, and yeah i found mine and it was about 130 bytes p/s and at most 5k bytes p/s for like 2 sec before dropping to about 100bytes p/s.
it is cudaminer mining Dogecoin with a 660ti PE
You didn't have to watch it constantly. All you had to do was watch it for a minute or two every so often and figure an average. But at least you figured something out.
