Does the msi b550i gaming edge WiFi has a type c header?
Guest
Can I use the msi  b550i motherboard with a nzxt h210 case
I want to know that if I use the motherboard will I lose the type c connectivity of the front panel?
So does it mean that I can use the type c of the case.
Yes
There it is
Make sure you use the quote button so that we can see your responses.
Primary PC:
The internal header on that board is a Gen 1 Type C (5Gbps) so it isn't as fast as a Gen 2 (10Gbps) that some other boards have. It will still work though but you won't get the full transfer speed.
No problem
