Will it work
Solved by Haro,
5 minutes ago, egyptman11 said:put the 8-pin only or do I have to buy a psu that supports this type connector
You only need an 8 pin. The extra 4 pin is for heavy overclocking which with a normal water / air cooler you won't do
A single 8 pin can provide up to 384w of power ( or can even go above that if the cables can handle more amps ) and you won't reach that any time soon as a causal user.
