Right, so I booted my computer today only to find that it did not boot into windows and instead took me to the BIOS where I am stuck. The storage device is coming up on the BIOS but it is not registering as a boot device so I cannot boot into windows. Any help would be great.
My specs are
Asus Tuf x570 gaming motherboard
ryzen 7 3700x
rtx 2070 super
1TB Samsung Evo 970 m.2 NVME SSD
https://linustechtips.com/topic/1219097-motherboad-problem-please-help/
Do you have a secondary drive ?
Clear the cmos and if you do
Unplug it and try.
Phone: Pixel 3a (Purple-ish).
Build Log:
Unplug it and try.
I only have 1 drive, I will do a Cmos reset now but I think it has something to do with the memory speeds because AMD ryzen master changed them earlier then this has happened so I am not too sure but I will give it a go.
If clearing cmos doesnt work, change the slots your ram are in. They should be in slots A2 and B2. Also enable xmp in the bios to get them to run at the advertised speed instead of 2133mhz.
I am far from an expert in this so please correct me if I’m wrong.
Quote or tag me so I can see your response
PSU Tier List
Motherboard Tier List
Graphics Card Cooling Tier List
CPU Cooler Tier List
SSD Tier List
PARROT GANG
Mentioned in 7/10/20 WAN Show
Mentioned in 7/15/20 Techlinked
Mentioned in 7/17/20 Techlinked
Mentioned in 7/31/20 WAN Show
Mentioned in 7/31/20 Techlinked
Mentioned in 8/3/20 Techlinked
Mentioned twice in 8/5/20 Techlinked
Mentioned twice in 8/7/20 Techlinked
Mentioned in 8/12/20 Techlinked
Mentioned in 8/19/20 Techlinked
Yeah, clearing the Cmos didn't work. Are you sure this will make my SSD register as a boot device?
11 minutes ago, LightBuld231 said:
Sorry for not replying @5x5 The last thing I did on the pc was do a test with AMD ryzen master and it restarted my PC and then this whole problem happened
If the drive is not visible at all in the BIOS then the SSD has simply failed.
If you've got another PC with an M.2 slot, might be worth testing the drive in that system
The Workhorse (AMD-powered custom desktop)
CPU: AMD Ryzen 7 3700X | GPU: MSI X Trio GeForce RTX 2070S | RAM: XPG Spectrix D60G 32GB DDR4-3200 | Storage: 512GB XPG SX8200P + 2TB 7200RPM Seagate Barracuda Compute | OS: Microsoft Windows 10 Pro
The Portable Workstation (Apple MacBook Pro 16" 2021)
SoC: Apple M1 Max (8+2 core CPU w/ 32-core GPU) | RAM: 32GB unified LPDDR5 | Storage: 1TB PCIe Gen4 SSD | OS: macOS Monterey
The Communicator (Apple iPhone 13 Pro)
SoC: Apple A15 Bionic | RAM: 6GB LPDDR4X | Storage: 128GB internal w/ NVMe controller | Display: 6.1" 2532x1170 "Super Retina XDR" OLED with VRR at up to 120Hz | OS: iOS 15.1
I also thought the drive was broken and when I tried to get Amazon to replace it they said they can't if data is on it. So how am I meant to delete the data of a broken drive.
Then reinstall the OS and format the drive then RMA it
