I was wondering if there is software that will allow me to create my own custom RGB patterns/effects for my fans. I've had a quick look around and cant seem to see anything.
The fans I am using are upHere argb fans that came with a controller box but no software. I can control them through RGB Fusion 2.0 but cant find any way to create my own effects, I can only use the built in options in RGB Fusion or the ones on the controller.
So is there software available that will let me go nuts on my fans or not?
https://linustechtips.com/topic/1218655-custom-argb-fan-software/
Thanks for that, I had a quick look there and its not something I'd be comfortable using as the warning states "There have been reports of Gigabyte motherboards having serious issues (bricking the RGB or bricking the entire board) when dumping certain devices." and "As of now, only Gigabyte RGB Fusion 2.0 boards have been reported to have issues."
Can you guess what motherboard type and brand I have? 😂
  • 11 months later...
Hey Logicaldrm I was going to download this but before I did this file you sent https://gitlab.com/CalcProgrammer1/OpenRGB reported as malicious on VirusTotal VirusTotal.com. I was wondering if that was true.
Alltheshots I was wondering what uphere fans are you using because mine are the 6pin uphere fans and i was wondering if this software works for those fans.
