First build: How important is memory validation for AMD?
Solved by Haro,
AMD validated or Intel validated just means that it was tested with an AMD/Intel cpu and it was validated to work with that cpu
That doesn't mean that an Intel validated ram won't work with an AMD cpu and vise versa
It doesn't matter for the most part.
smush ·
Posted in CPUs, Motherboards, and Memory2 -
asdasdasdasdasdasd ·
Posted in Hot Deals1 -
RipperDoc5456 ·
Posted in Troubleshooting6 -
Nebcs ·
1
FancyPants101 ·
