I was looking into a good pair of wireless earbuds to wear when I ride my bike.  I ride in pretty much all weather and wanted some good quality waterproof earbuds.  The ones that have caught my eye are the Jabra elite active 75t and the AKG N400 but wanted to see if anyone on here has any recommendations before I pull the trigger.
https://linustechtips.com/topic/1218468-wireless-earbuds/
I’ve been happy with my Powerbeats 3. The newer version (Powerbeats pro?) has no wire between the earbuds.
I am far from an expert in this so please correct me if I’m wrong.
Quote or tag me so I can see your response
PSU Tier List
Motherboard Tier List
Graphics Card Cooling Tier List
CPU Cooler Tier List
SSD Tier List
PARROT GANG
Mentioned in 7/10/20 WAN Show
Mentioned in 7/15/20 Techlinked
Mentioned in 7/17/20 Techlinked
Mentioned in 7/31/20 WAN Show
Mentioned in 7/31/20 Techlinked
Mentioned in 8/3/20 Techlinked
Mentioned twice in 8/5/20 Techlinked
Mentioned twice in 8/7/20 Techlinked
Mentioned in 8/12/20 Techlinked
Mentioned in 8/19/20 Techlinked
https://linustechtips.com/topic/1218468-wireless-earbuds/#findComment-13790752
I have a pair of 75t's and they're by far my favorite earbuds
They fit super snug, mono mode works very well and the charging case is very small.
There is an emphasis on bass, so keep that in mind if that's not your jam.
https://linustechtips.com/topic/1218468-wireless-earbuds/#findComment-13790757
Seem to recommend these on basically every thread but Cambridge Audio Melomania 1s. Mine replaced a set of Sennheiser Momentum Frees that I thought I'd lost but then found again. Despite being 30% cheaper they sound much better.
[ P R O J E C T _ M E L L I F E R A ]
[ 5900X @4.7GHz PBO2 | X570S Aorus Pro | 32GB GSkill Trident Z 3600MHz CL16 | EK-Quantum Reflection ]
[ ASUS RTX4080 TUF OC @3000MHz | O11D-XL | HardwareLabs GTS and GTX 360mm | XSPC D5 SATA ]
[ TechN / Phanteks G40 Blocks | Corsair AX750 | ROG Swift PG279Q | Q-Acoustics 2010i | Sabaj A4 ]
P R O J E C T | S A N D W A S P
6900K | RTX2080 | 32GB DDR4-3000 | Custom Loop
https://linustechtips.com/topic/1218468-wireless-earbuds/#findComment-13791265
