I'm looking to get a new graphics card which I got help with in an earlier topic in the Graphics Card place. I have a Omen by hp 880-123no and the stock PSU is 500w and I ran a test with Neweggs Power Supply Calculator which said under 500w with an RTX 2080, but to be on the safe side I have decided to upgrade the power supply to maybe a 650 or 850w with a 80+ Gold or higher certification to save on the monthly bill. But I'm having a bad time trying to understand the different form factors and sizes because on the Newegg website they only talked about like ATX, ATX12V and AT but my motherboard is a uATX which I think is a microATX. Should the PSU size be the same as the motherboard size? Or are the PSU sizes a totally different thing? Btw which size do u think will be the best? And if u have the time give me some examples! :) Thanks!
https://linustechtips.com/topic/1217935-upgrade-power-supply-help/
1 minute ago, wetdragonkiIler said:
80+ Gold or higher
Efficiency is not quality.
Atx PSU is not the same as an atx PSU
Open should fit an atx PSU tho.
2 minutes ago, wetdragonkiIler said:
Budget for the PSU and what components?
Phone: Pixel 3a (Purple-ish).
Build Log:
Just now, wetdragonkiIler said:
Around 100$ and 150$
Rm550x
Tx550m
MWE gold
Straight power 11
AMP from phanteks is also decent.
Build Log:
