So I 1 year ago I bought a graphics card that was mining bit coin. And now it started buzzing and oberheating. I changed the thermal paste but it is still overheating and there is a buzzing sound coming from it.
Here are my specs:
r9 380x
intel i5 2500
ram 8gb ddr3
https://linustechtips.com/topic/1217811-gpu-problem/
Make sure the cooler is mounted correctly
And by buzzing do you mean coil whine ?
Also what are your temps ? Lol.
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1217811-gpu-problem/#findComment-13785129
Just now, highrusher said:
the temp for the gpu is 80
That's not overheating lol.
They're decent.
Build Log:
https://linustechtips.com/topic/1217811-gpu-problem/#findComment-13785169
30 minutes ago, _DeXTeR_ said:
Buzzing comes from transistors coils its called coil whine, its mostly bcs bad quality transistors Gigabyte main problem.
And for Heating problem maybe you should try manually to set fan speed curve.
in the game i have the max of 50fps -_- what foes it mean if I set the afterburner to max 120 it wont do anything
https://linustechtips.com/topic/1217811-gpu-problem/#findComment-13785178
1 minute ago, highrusher said:
in the game i have the max of 50fps -_- what foes it mean if I set the afterburner to max 120 it doesnt do anything
No point of OC the card since R9 are not very overclockable...
Please do not take offence for my apparent confusion or rudeness,it's not intent me to be like that,it's just my BPD,be nice to me,and I'll return twice better,be rude and usually I get easly pissed of...I'll try to help anyone here,as long as it's something I dealt with,and even if you think I'm rude or not polite,forgive me,  it's not me it's my BPD.
Thanks for understanding.
https://linustechtips.com/topic/1217811-gpu-problem/#findComment-13785184
80C is fine for full load, and the buzzing is most likely coil whine.
In what game? The 380X is a rebranded 280X which is a rebranded HD 7970 GHz Edition which was released in 2012. You can't expect it to max out the latest and greatest AAA titles.
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
https://linustechtips.com/topic/1217811-gpu-problem/#findComment-13785475
destiny 2
https://linustechtips.com/topic/1217811-gpu-problem/#findComment-13806560
