Hello everyone.
Since my old 7970 was DOA and i got a refund. I'm thinking about buying an GTX770-DC2OC-2GD5.
But... I might possibly run into a slight problem. When i was checking the dimensions for my case to check if the card isn't too long, I found on a random website (not CM, since it's down) that my case, CM Centurion 5 II, has a max gpu card lenght of around 250mm.
Guess what. The 770 is 271.7mm. I don't know if it'll actually fit. You might in hindsight say it won't fit. But when looking up my old 7970 that did BARELY fit in my case, i found it it was actually 305mm. So i'm quite confused right now. I was lucky with the 7970 that i could barely fit the second power connector.
Do you think i'll be able to cut a piece out of my case when it ends up not fitting?
And do you think this will just fit?
CPU:
Intel Core i5 2500k - Motherboard: Asus maximus iv gene-z - RAM: 2x Corsair Vengeance Blue 4GB DDR3-1600 CL9 - GPU: ASUS GTX 770 DirectCU II
Case: Coolermaster Centurion 5 II - Storage: Crucial M4 128GB, Seagate barracuda 3TB PSU: XFX 650W XXX Edition Modular PSU - Keyboard: Ducky Shine 2 Pro
Mouse: Razer Deathadder 2013 - Sound: Razer Characias
https://linustechtips.com/topic/121749-will-it-fit/
Just remove a HDD cage if it doesn't fit.
It's not clipping the HDD cage. It's actually clipping the dvd drive cage if you know what i mean. And i don't think that's removeable.
CPU:
https://linustechtips.com/topic/121749-will-it-fit/#findComment-1620796
The 770 is 271.7mm. But when looking up my old 7970 that did BARELY fit in my case, i found it it was actually 305mm.
You just answered the question yourself....
CPU: AMD R7 5800x | GPU: XFX 5500XT 4GB | RAM: 2x8GB Kingston Fury Renegade 3600MHz CL16 | Cooling: Deepcool Gammaxx L360 | MB: Aorus B550 Elite V2 | Storage: Samsung 850 Evo 250gb & WD20EAZX | Case: Antec DF700
Lenovo ThinkPad Yoga 460: Intel 6200U | 8GB | 256GB SSD | Active pen
https://linustechtips.com/topic/121749-will-it-fit/#findComment-1620797
if the card is shorter than the dimensions of the 7970, you should be fine. NVIDIA cards don't tend to be long.
That title though hueheueuheuehuehueheuheuheuheuehuehuehueheuheuheuhehuehueheuheuehuehueheuiueuheuheuheuheuheeuheuheueuheuheeuh
Andres "Bluejay" Alejandro Montefusco - The Forums Favorite Bird!!!
Top Clock: 7.889 Ghz Cooled by: Liquid Helium
#ChocolateRAM #OatmealFans #ScratchItHarder #WorstcardBestoverclocker #CrazySexStories #SchnitzelQuest TS3 SERVER
https://linustechtips.com/topic/121749-will-it-fit/#findComment-1620800
Ok thanks. It was probably a dumb question, but better be safe than sorry right ;)
CPU:
https://linustechtips.com/topic/121749-will-it-fit/#findComment-1620813
