So I recently changed my motherboard and cpu as well as memory. First time doing this all I did was install them and boot up the pc. But now when playing games they get choppy. Did I do something wrong? Is it a bottleneck?
Currently using
Ryzen 7 3700x - cpu
Nvidia rtx 2060 - gpu
Corsair vengeance rgb 32gb
https://linustechtips.com/topic/1217410-please-help/
Just now, NZgamer said:
What games? I'd say the 2060 is a bit weak for the 3700x but it shouldn't stutter with that.
Well I was playing an mmo called neverwinter. Which isn't very graphic demanding. When I tabbed out my cpu was running at 90 percent and then immediately jumped down to 14 percent
https://linustechtips.com/topic/1217410-please-help/#findComment-13782023
5 minutes ago, NZgamer said:
What kind of temps are you getting under load? I'd recommend MSI Afterburner for this so that you can get the details in game without having to tab out
I can't seem to find cpu Temps in afterburner. But my cpu fan isn't speeding up any.
https://linustechtips.com/topic/1217410-please-help/#findComment-13782035
1 minute ago, Pokajake said:
Enable xmp/docp
If that didn't do anything
Ddu the drivers.
Temps?
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1217410-please-help/#findComment-13782036
23 minutes ago, NZgamer said:
I meant to use the overlay during your game, I should have been more clear, so that's my fault
First, go in here and set a custom toggle keybind
Now, go to this tab and select the data that you want to see during your game:
Then when you're in the game press your toggle key (but make sure you leave afterburner open in the background)
GPS runs at about 60 celsius when under load. That's what it showed me.
https://linustechtips.com/topic/1217410-please-help/#findComment-13782099
Currently using
Ryzen 7 3700x - cpu
UPDATE: after loading up the bios it seemed to do something and fixed itself. No more stutter.
https://linustechtips.com/topic/1217410-please-help/#findComment-13782105
