Hey,
I hope this is the right place to post this, so fingers crossed.
I want to buy a Raspberry Pi 4B 8Gb version. I just didnt know what case. With that comes the problem of thermals.
I was wondering if people here have experience with Pi's and if they can say something usefull about keeping them cool.
Right now I am in debate on having a case with purely passive cooling: https://www.elektor.com/pimoroni-aluminium-heatsink-case-for-raspberry-pi-4
Or get one with quite some passive cooling but also 2 mini fans: https://www.elektor.com/joy-it-armor-aluminium-heatsink-case-with-dual-fan-for-raspberry-pi-4
I am however worried that they will produce too much noise. I was also considering getting the first option and somehow applying a bigger fan on top that does the cooling, this would quite a lot of work.
Im not sure yet what the workload will be, but I want to be sure that I can put a load on it without having to worry about getting it too hot.
Thanks for your advice!
https://linustechtips.com/topic/1217228-advice-on-raspberry-pi/
I got SBCs that run a lot hotter than Broadcom chips and I just use tiny vram heatsinks on them and it works fine. As long as you arent going to be overclocking your RPI you are fine without fans or even a heatsink. I have to say that 8G ram is quite a lot for RPI, may I ask what you intend to do with it?
https://linustechtips.com/topic/1217228-advice-on-raspberry-pi/#findComment-13780475
@Niekao
https://geizhals.de/52pi-ice-tower-cpu-cooling-fan-for-raspberry-pi-ep-0107-a2193476.html
If you want to be the coolest kid
Edited by Drama Lama
Hi
hi
https://linustechtips.com/topic/1217228-advice-on-raspberry-pi/#findComment-13780477
I like not being limited by hardware. I've gamed on complete crap for like 8 years and now I've got a good computer. I dont want to sound like a spoiled brat, but I dont know what I'll do yet, I just do want to be limited if I do decide I want to do something that requires a lot of ram
https://linustechtips.com/topic/1217228-advice-on-raspberry-pi/#findComment-13780488
Take a look at explaining computers on youtube. His entire channel is basically all about SBC's.
At me or quote me, I want to hear your opinion.
Hopefully anything I say is factually correct. Sorry for any mistakes in advanced.
https://linustechtips.com/topic/1217228-advice-on-raspberry-pi/#findComment-13780491
2 minutes ago, Drama Lama said:
Well that is definitely something. But same problem, I wonder if the fan will be too obnoxious
https://linustechtips.com/topic/1217228-advice-on-raspberry-pi/#findComment-13780497
Fans are always noticeable in a room with no other noise, thats why I dont run fans on my SBCs.
I have yet to see someone needing more than 2Gs of ram with a RPI. I run octoprint, openvpn client, openmediavault, transmission and pi-hole on OPZ with 512mb ram and I only use %40 of the ram. 8G is WAY too overkill if you are not sure what you are going to do.
https://linustechtips.com/topic/1217228-advice-on-raspberry-pi/#findComment-13780526
I have yet to see someone needing more than 2Gs of ram in RPI. I run octoprint, openvpn client, openmediavault, transmission and pi-hole on OPZ with 512mb ram and I only use %40 of the ram. 8G is WAY too overkill if you are not sure what you are going to do.
MHm okay I will consider it. Im going to need one for my unversity work, dont know yet what I will need to do with it and I want one to host a website for myself.
https://linustechtips.com/topic/1217228-advice-on-raspberry-pi/#findComment-13780536
