What are they priced at ?
I would personally go with the 580 but it all depends on the price
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1217024-need-help-deciding-gpu/#findComment-13778744
26 minutes ago, Kurosoki said:
I can't decide on what gpu should I buy for the long run (I won't be able to upgrade my gpu for 4 to 5 years) so,
Should I buy Rx 580 8gb or Rx 5500 tx 4gb
RX580 is "a safer bet" for long term usage due to the VRAM. However it's already a pretty old card at this point, so another 5 years seems pretty unlikely.. but depends on which games you're planning to play.
I'd wait till Q3/Q4 this year for the new lineup from both AMD and Nvidia before deciding if you can afford the wait.
https://linustechtips.com/topic/1217024-need-help-deciding-gpu/#findComment-13778784
Hate to be *that* guy, but neither? Those are *okay* cards for today, but if your goals is not replace them for 4-5 years, they won't make it. If you want a good experience for that long, your going to have to put some money up, with a 5600 XT at the low end, just because it punches well above its weight class, but probably closer to a 2070 or 2080.
CPU: AMD Ryzen 9 9950X3D · Cooler: Noctua NH-D15S Chromax.black · Motherboard: Gigabyte Auros X670 Elite AX · RAM: G.Skill Flare X5 64GB (2 x 32GB) DDR5 6000MHz CL30 · Graphics Card: Zotac NVIDIA GeForce RTX 4070 Super Twin Edge OC 12GB · Boot Drive: 1TB XPG Gammix S70 Blade NVMe SSD · Game Drive: 2TB WD SN850X NVMe SSD · PSU: Seasonic Focus GX V3 1000W 80+ Gold · Case: Fractal Design North Mesh · Monitor: MSI Optix MAG342CQR 34” UWQHD 3440x1440 144Hz · Keyboard: EPOMAKER x Aula F99 Wireless Mechanical Keyboard · Mouse: Logitech G309 Lightspeed Wireless Gaming Mouse
https://linustechtips.com/topic/1217024-need-help-deciding-gpu/#findComment-13779610
