I'm having some problems with my PC..
This is the spec:
CPU-Amd 2200g
GPU-Evga gets 1050 2gb
RAM- 8gb at 2666 single
Motherboard- GIGABYTE B450M DS3H
This is the problem:
six months ago I build this pc at the time the gpu would start up but screen would go blue like if the computer was off but everything would be running but sometime the screen would do the same but in instead of blue it would turn green, light pink or cream (not all the colour at the same time) when I restart the computer one out of the three I would get. It did that for a day or two try different things and it worked but it has started back now. Can anyone help and tell me why is this happening?????
https://linustechtips.com/topic/1216934-need-help/
is your gpu plugged in correctly?
what is your power supply
monitor?
did you try using a different cord for display output?
different output?
have you tried contacting evga support?
PC specs:
Ryzen 9 3900X overclocked to 4.3-4.4 GHz
Corsair H100i platinum
32 GB Trident Z RGB 3200 MHz 14-14-14-34
RTX 2060
MSI MPG X570 Gaming Edge wifi
NZXT H510
Samsung 860 EVO 500GB
2 TB WD hard drive
Corsair RM 750 Watt
ASUS ROG PG248Q
Razer Ornata Chroma
Razer Firefly
Razer Deathadder 2013
Logitech G935 Wireless
https://linustechtips.com/topic/1216934-need-help/#findComment-13778101
