I need some help with my case fans
Anonymous 99
Hi.
So my case has 4 fans but my motherboard only has 3 fan connectors... will it matter if I plug the 4th fan in the power supply with the molex cable?
Thanks!
fan splitters are quite cheap and are much better than molex, you can get some from amazon
Main PC [The Rig of Theseus]:
CPU: i5-8600K @ 5.0 GHz | GPU: GTX 1660 | RAM: 16 GB DDR4 3000 MHz | Case: Lian Li PC-O11 Dynamic | PSU: Corsair RM 650i | SSD: Corsair MP510 480 GB |  HDD: 2x 6 TB WD Red| Motherboard: Gigabyte Z390 Aorus Pro | OS: Windows 11 Pro for Workstations
Secondary PC [Why did I bother]:
CPU: AMD Athlon 3000G | GPU: Vega 3 iGPU | RAM: 8 GB DDR4 3000 MHz | Case: Corsair 88R | PSU: Corsair VS 650 | SSD: WD Green M.2 SATA 120 GB | Motherboard: MSI A320M-A PRO MAX | OS: Windows 11 Pro for Workstations
Server [Solution in search of a problem]:
Model: HP DL360e Gen8 | CPU: 1x Xeon E5-2430L v1 | RAM: 12 GB DDR3 1066 MHz | SSD: Kingston A400 120 GB | OS: VMware ESXi 7
Server 2 electric boogaloo [A waste of electricity]:
Model: intel NUC NUC5CPYH | CPU: Celeron N3050 | RAM: 2GB DDR3L 1600 MHz | SSD: Kingston UV400 120 GB | OS: Debian Bullseye
Laptop:
Model: ThinkBook 14 Gen 2 AMD | CPU: Ryzen 7 4700U | RAM: 16 GB DDR4 3200 MHz | OS: Windows 11 Pro
Photography:
Cameras:
Full Frame digital: Sony α7
APS-C digital: Sony α100
Medium Format Film: Kodak Junior SIX-20
35mm Film:
Lenses:
Sony SAL-1870 18-70mm ƒ/3.5-5.6
Sony SAL-75300 75-300mm ƒ/4.5-5.6
Meike MK-50mm ƒ/1.7
PSA: No, I didn't waste all that money on computers, (except the main one) my server cost $40, the intel NUC was my old PC (although then it had 8GB of ram, I gave the bigger stick of ram to a person who really needed it), my laptop is used and the second PC is really cheap.
I like tinkering with computers and have a personal hatred towards phones and everything they represent (I daily drive an iPhone 7, or a 6, depends on which one works that day)
I am currently broke so I can't afford one.
4 minutes ago, Anonymous 99 said:
Hi.
Thanks!
Yes you can, it will run at 100% all of the time though.
https://www.amazon.com/Winncon-Splitter-Converter-Sleeved-Duplicator/dp/B07WN4G7KC/ref=sr_1_8?dchild=1&keywords=fan+splitter&qid=1593636678&sr=8-8
If you lived In Milan I would be happy to give you one
Laptop:
Photography:
Cameras:
35mm Film:
Lenses:
Meike MK-50mm ƒ/1.7
Oh ok. So it is probably best if I plug my exhaust fan to the PSU an the other 3 intake fans to the motherboard.
Thanks for the reply.
Well I live in Slovenia so we are not that far away. LOL
true! you would spend more in gas though...
since you live in europe amazon.it or .de are your best options, here are some liks for cheapo fan splitters
https://www.amazon.it/Demiawaking-Connettore-Alimentazione-Estensione-Ventilatore/dp/B07537N4NK/ref=sr_1_16?__mk_it_IT=ÅMÅŽÕÑ&dchild=1&keywords=fan+splitter&qid=1593637307&sr=8-16
or
https://www.amazon.de/InLine-33328Y-Y-Kabel-Stecker-schwarz/dp/B01BPSOU38/ref=sr_1_3?crid=T8926P5ODD8G&dchild=1&keywords=lüfter+y-kabel&qid=1593637370&sprefix=fan+spl%2Caps%2C248&sr=8-3
Laptop:
Photography:
Cameras:
35mm Film:
Lenses:
Meike MK-50mm ƒ/1.7
Thanks! But I think I will just plug it in the PSU rather than buying it and then waiting for it... I waited more than a week longer than it said for my PC parts
ok, the fans will run at max, but if they are quiet enough it shouldn't be too big of a problem
Laptop:
Photography:
Cameras:
35mm Film:
Lenses:
Meike MK-50mm ƒ/1.7
