Hello,
Hope you guys are having a good day so far.
I've been having overheating issues with my Dell Inspiron 15 laptop. I play games like Valorant on it, so overheating is not a big surprise.
I've tried limiting the processor state up to 80%, but it still overheats, and I don't want to lower it any further, worried that it would lower gaming performance.
So I considered getting a cooling pad. Do you think it would be worth it? Here's what I'm considering:
https://www.amazon.com/TopMate-TM-3-12-15-6-2500RPM-Designed/dp/B01J18006K/ref=asc_df_B01J18006K/?tag=hyprod-20&linkCode=df0&hvadid=198138936631&hvpos=&hvnetw=g&hvrand=8055758414799120828&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=1014204&hvtargid=pla-381252497188&psc=1
https://linustechtips.com/topic/1216504-cooling-pad-recommended/
23 minutes ago, Moohsan said:
Hello,
I just order this laptop cooler
https://www.newegg.com/rosewill-rwnb16a-laptop-cooler/p/N82E16834969087
"Whatever happens, happens." - Spike Spiegel
On most Dell laptops, the fans are on the bottom. You might want to try raising it with the center exposed (like putting 2 small blocks on the left and right so the center has good airflow), just don't cover up the openings. If you put it on a flat surface, the fans are covered on most laptops. I haven't used a laptop cooler so I can't verify if they actually work, but I know that external game console fans do nothing.
Quote or mention me or I won't be notified of your reply!
Main Rig: R7 3700x New!, EVGA GTX 1060 6GB, ROG STRIX B450-F Gaming New!, Corsair RGB 2x16GB 3200MHz New!, 512GB Crucial P5, 120GB Samsung SSD, 1TB Segate SSHD, 2TB Barracuda HDD
MacBook Pro 14" (M1 Max, 32GB RAM)
Links: My beautiful sketchy case | My website
I've found they can be some help, but only if the bottom of the laptop is metal or the air intake is on the bottom. Generally the fans in cooling pads are pretty anemic as well. If you're not planning to try to use it on the go it might be a better idea to grab a normal mesh laptop stand, then point a full size tilt fan at the bottom of it.
¯\_(ツ)_/¯
Desktop:
Intel Core i7-11700K | Noctua NH-D15S chromax.black | ASUS ROG Strix Z590-E Gaming WiFi  | 32 GB G.SKILL TridentZ 3200 MHz | ASUS TUF Gaming RTX 3080 | 1TB Samsung 980 Pro M.2 PCIe 4.0 SSD | 2TB WD Blue M.2 SATA SSD | Seasonic Focus GX-850 Fractal Design Meshify C Windows 10 Pro
Laptop:
HP Omen 15 | AMD Ryzen 7 5800H | 16 GB 3200 MHz | Nvidia RTX 3060 | 1 TB WD Black PCIe 3.0 SSD | 512 GB Micron PCIe 3.0 SSD | Windows 11
