So I had a Behringer 502 mixer and had a sound card Creative Sound Blaster Z and a AT2020, I had problems with people on discord and ingame hearing them talk and the game sound coming through my mic. So I bought a Scarrlett Solo 3rd gen. but not my headphones sound garbage, my headphones are HD6XX. Do I need a headphone amp to make it better? If I have it pluged into the Audio mixer or my computer directly it doesn't sound good, It sounded great when I just pluged it into my Sound card
Any Ideas
Main Rig | I9-9900K @ All Core 5.3 1.37V | Asus 2080TI | NZXT X72 | SM951 256GB | Samsung 850 Pro 500GB | Seagate 2TB | Corsair Vengeance RGB 32GB 3200MHz | RM850I | Corsair 570X
Ether Server | 2x Xeon E5-2660 | Supermicro X9DR3-F | Deepcool MATREXX 55 | 128GB Toshiba THNSNJ128GCS | 2x WD 4TB Red | ECC 64GB Samsung 1RX4 PC3L-12800R
https://linustechtips.com/topic/1216346-headphone-audio-quality-problems/
Then you likely need an amp. Do they just sound quiet and poor quality?
I also don't understand your original issue. You literally heard in game sound coming through your microphone?
Gaming Build:
CPU: Ryzen 7 3800x   |  GPU: Asus ROG STRIX 2080 SUPER Advanced (2115Mhz Core | 9251Mhz Memory) |  Motherboard: Asus X570 TUF GAMING-PLUS  |  RAM: G.Skill Ripjaws DDR4 3600MHz 16GB  |  PSU: Corsair RM850x  |  Storage: 1TB ADATA XPG SX8200 Pro, 250GB Samsung 840 Evo, 500GB Samsung 840 Evo  |  Cooler: Corsair H115i Pro XT  |  Case: Lian Li PC-O11
Peripherals:
Monitor: LG 34GK950F  |  Sound: Sennheiser HD 598  |  Mic: Blue Yeti  |  Keyboard: Corsair K95 RGB Platinum  |  Mouse: Logitech G502
Laptop:
Asus ROG Zephryus G15
Ryzen 7 4800HS, GTX1660Ti, 16GB DDR4 3200Mhz, 512GB nVME, 144hz
NAS:
QNAP TS-451
6TB Ironwolf Pro
You have open back headphones, depending how sensitive you have your microphone set up and how loud you have the volume through the headphones, of course the mic will eventually pick that noise up.
For a solution that is bearable and won't cost you any more:
1) use push to talk
2) enable discords sound suppression (in beta atm)
3) optional if 1 and 2 don't fix it -- create a microphone noise gate that only lets your voice through but not external noises.
Any Ideas
Mic interfaces aren't known for good amp in headphones.
PM/DM me if you have any questions about audio.
My PC specs & audio gear
CPU > Intel core i7 14700K, GPU > RTX 4070 ProArt, RAM > Corsair Vengeance DDR5 2x16gb 5600mhz, Motherboard > Asus ROG Strix B760-F, Storage > 1TB M.2  & 500GB M.2 Kingston, Cooling > H150i Elite, PSU > MSI A850GL
🎧Current Audio Setup🎧
HifiMan Ananda Nano, HE400se, X2HR
Soundblaster AE-9 Soundcard
AKG P420 Mic
Other peripherals
Monitor > Samsung Odyssey OLED G9
Keyboard > Keychron Q3 HE TKL
Mouse > Logitech G Pro 2 Lightspeed
Mousepad > X-Gamer XG++ XXL mousepad
Read this post if you want a "gaming" headset ;)
