I need help starting my pc up
Solved by Guest,
Read your motherboard manual, there should be a diagram of what the headers do. Find the one that is the BIOS or CMOS header and take off the jumper or if they've been pushed together pull them apart. Then your computer should work.
Featured Topics
rickymohk ·
Posted in General Discussion1 -
Rbakker02 ·
BaidDSB ·
Posted in General Discussion5 -
1
Mistr J ·
Posted in Troubleshooting3 -
2
4
2
coolbean28 ·
Posted in Graphics Cards8
