I was watching a video last night when my left audio channel suddenly cut out completely. I'm using a schiit modi multibit / magni3 / DT 1770 pros but the problem doesn't seem to be with any of the connectors (it's still there with a different set of headphones off of front IO) I've updated / uninstalled / reinstalled all of my audio drivers but still nothing. The levels are at 100 for left and right in audio settings. Thoughts?
system is
Asus Z170-A
EVGA gtx 1070
i7 6700k
thoughts?
update: for some reason both channels work when using the rear RCA on the Magni3, it's now also working with rear IO but still not front IO, so it seems like it is a hardware problem (or rather two of them)
https://linustechtips.com/topic/1216238-no-left-audio-channel/
system is
Asus Z170-A
EVGA gtx 1070
i7 6700k
thoughts?
I'd say locate where the front IO is plugged in on your motherboard. Disconnect and then reconnect your front IO
https://linustechtips.com/topic/1216238-no-left-audio-channel/#findComment-13772113
What does your configuration look like? I'm assuming a 3.5mm to RCA cable, correct? To me it sounds like a bad port or cable (likely cable). Buy yourself a nice gold plated version of the same cable and it should last you a long time.
QUOTE ME IF YOU WANT A REPLY!
PC #1
Ryzen 7 3700x@4.4ghz (All core) | MSI X470 Gaming Pro Carbon | Crucial Ballistix 2x16gb (OC 3600mhz)
MSI GTX 1080 8gb | SoundBlaster ZXR | Corsair HX850
Samsung 960 256gb | Samsung 860 1gb | Samsung 850 500gb
HGST 4tb, HGST 2tb | Seagate 2tb | Seagate 2tb
Custom CPU/GPU water loop
PC #2
Ryzen 7 1700@3.8ghz (All core) | Aorus AX370 Gaming K5 | Vengeance LED 3200mhz 2x8gb
Sapphire R9 290x 4gb | Asus Xonar DS | Corsair RM650
Samsung 850 128gb | Intel 240gb | Seagate 2tb
Corsair H80iGT AIO
Laptop
Core i7 6700HQ | Samsung 2400mhz 2x8gb DDR4
GTX 1060M 3gb | FiiO E10k DAC
Samsung 950 256gb | Sandisk Ultra 2tb SSD
https://linustechtips.com/topic/1216238-no-left-audio-channel/#findComment-13772136
